Question about RCA 32V524T TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Model number 32V524T 32 In RCA Tv all of a sudden our TV just went out no picture and no sound but a BEEPING noice when the power comes on. What can the problem be and can we fix it ourselves? exactly 2 years from the date of purchase we were watching our tv and it just went black. no picture no sound and a chirping sound came from the back. we unplugged it and tried again the light blinks a couple times and a chirp but again no picture no sound and it will not shut off. can we fix it and how much?
  • 4 more comments
  • Jlletizia May 21, 2008
    My sons TV RCA 27" has sound but no picture - the picture will come on and stay on for about 15 minutes and go out again for about 5 minutes and come back on again. And than at other times no picture at all for time on end? (The TV is about 8 years old) I spoke to Verizon Fios and they think possibly it could be the coax cable - want $91 to come look at it. I am just wondering if it could be the picture tube itself? I don't waste the money buying a cable or having them come to look at it? Please advise
    Thanks
  • kimjeff Jun 04, 2008
    We bought our 32 inch TV 1 year and 4 months ago we were watching it and it made a crack sound and the pitcure went out we can still not get the pitcure to come in.
    Thanks
  • asweeney222 Jul 07, 2008
  • gordonsmgr Jul 23, 2008
    Tv picture went black and wont come back on. Tv makes a chirpping sound. unplugged and re plugged and same problem...wont turn on only makes a chirpping sound
  • houghtaling1 Dec 24, 2008
    I can watch tv for a litle while but sooner or later it goes black but the sound stays on.
  • Anonymous May 10, 2009
    Exact same problem, I also have owned mine for 2 years.
    Genius:
  • 1,139 Answers
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
2 Suggested Answers
  • 133 Answers
SOURCE: CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Posted on Mar 15, 2008
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
CAN IT BE FIX?
Mar 15, 2008 | RCA 32V524T TV
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
Rca 32v524t chassis-atc010a
replaced,off/on vol,up and down,and channel up and down.
Nov 21, 2007 | RCA 32V524T TV
RCA 32V524T
Probable EEPROM issue--What is the service #? (Has three additional characters after model #. EXPERIMENT==1)remove EEPROM-be careful not to damage it. 2)Install 8 pin plug-in socket--observe pin 1 indicator. 3)Plug back in original IC==may work ok,if not replace w/pre-programmed IC from HB Electronics.
Oct 03, 2007 | RCA 32V524T TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
RCA 32V524T TV Logo
1,377 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
