HP Compaq Presario SR1830NX PC Desktop Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I listen to streaming audio while I surf the net. While listening to streaming audio, I get a "stutter", when I click a link in the window I'm surfing. Never have experienced this, even on my 10 year old Dell dimension.
Anonymous
Level 3:
Genius:
  • Master 1,043 Answers
  • Posted on Mar 28, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1043
Questions
Helped
286030
Points
3188
This will usually only happen if you have so many programs running in the background that your system resources are maxed out. The processor has to momentarily stop one process to go to the link that you clicked on. Check your task manager and see what you have left for resources. You can probably go through and kill a number of background tasks without causing any issues. If you're not sure what a particular task is for type in the name on Google. There are a number of sites on the web that will tell you what pretty much all of your tasks are connected to.
How do I fix my ps4's audio stutters. I have it hooked up directly to my SANSUI HDMI tv via HDMI cord.
Could it be the internet connection sometimes is not fast enough? or someone else is downloading from the net the same time, or just streaming music or video over the net. All kind of reasons why the sound could stutters.
1helpful
How do I turn off automatic streaming?
This is a suggestion. Go to settings on your phone, click on Bluetooth, if you're using the Legend at this time, click on legend. You should show two profiles, call audio and media audio, turn off media audio by removing the checkmark in the box. Hope this helps.
What is causing my audio stutter
Hi There,
Audio stutters or freezing can be caused by more than a few things. Your computer may not have enough RAM - in which case, install more RAM. If you're running fifty things at once while trying to listen to music, that may the issue.
Sometimes an incorrect driver can be the cause. Go to the dell website and update your audio driver for your specific model.
How do I listen to music through the bluetooth
Listen to music with the Plantronics Explorer 220:
Unfortunately the Explorer 220 was not designed for music, it does not have the technology built in to stream audio. Headsets must have the Bluetooth A2DP profile and technology to be able to stream music. Like the Plantronics Voyager Pro+ and BackBeat models. Here are the links for these below.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/ipod-mp3-mobile.html
Good luck from Headsets Direct - 800-914-7996.
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Audio Problems
try to install the audio driver
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
