Question about Amana ACF4215 Electric Kitchen Range
F2 amana acf4215ac
F2 code came up, tried to reset it like the manual said, but didn't work bake oven element heats up even without bein turned on. what could it be and is it the temp sensor, will this do that?
    President:
  • Amana Master
  • 2,651 Answers
F-2 is a "oven too hot" fault. says to replace sensor. that wouldnt make the unit heat with out being on though
Posted on Mar 14, 2008
Amana oven does not comeon
Posted on Dec 30, 2008
SOURCE:
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Error code f2 after replacing sensor.
If the sensor utilizes a plug, it is not uncommon for the plug connection to become intermittent. Cut the plug off the sensor and the wire harness. Directly 'hard wire' the sensor wires to the harness wires using CERAMIC wire nuts.. (no polarity here, sensor is a resistive element) regular plastic wire nuts will melt. If problem persists thereafter, the electronic control may have to be replaced.
Jun 08, 2008 | Kenmore 47834 / 47832 / 47839 Electric...
Amana ACF4215AC, F2 code
ifyour oven heatsup with oout turning it on, either you have a short in the erc/overlay. Or a wire is shorting againt the metal frame somewhere.
Mar 13, 2008 | Amana ACF4215 Electric Kitchen Range
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Amana ACF4215 Electric Kitchen Range Logo
384 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
