Question about Amana ACF4215 Electric Kitchen Range
Amana ACF4215AC, F2 code
My amana acf4215ac range, the oven automatictly heats up without the oven turned on. An F2 code came up, reset it like the manufacture said but still doing the same thing, Could it be the Temp sensor? Had this problem like a year or 2 ago and reset it and it worked.
    President:
  • Amana Master
  • 2,651 Answers
Ifyour oven heatsup with oout turning it on, either you have a short in the erc/overlay. Or a wire is shorting againt the metal frame somewhere.
Posted on Mar 14, 2008
SOURCE:
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
I have an Amana oven with Model # ACF3325AS. A month ago I had a code F3, which a repair man resolved. Now I've got a F2 code stating that the oven is overheating. Can you help with what part I'm...
Hi
F2/F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 25, 2011 | Amana ACF3325AS Dual Fuel (Electric and...
Amana Model ARG7102W ERROR F02
Hello, Thank You for using FixYa. I will be helping you today.It means runaway temperature. Test oven sensor for 1100ohms if out by more than ten ohms replace sensor.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kitchen Ranges
F2 warning, oven won't turn off
Hi leelarupa,
The F2 failure code indicates that the oven is too hot. To correct this error you need to replace the oven temperature sensor.
Hope it helps.
Thank you for using FixYa.
Jun 02, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Describe your amana arg7800ww Gas Kitchen Range
can't get the oven to go on to bake. can you help me solve this problem thank you.
Mar 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
The oven light will not go off when the door is closed on my Amana AGDS902. any recommendations?
Check to make sure there is no switch to manually turn on the oven light. Most have a switch now to turn them on without opening the door so you can check the food without letting out the heat. Hope this helps.
Sep 12, 2009 | Amana AGDS902 Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
F2 amana acf4215ac
F-2 is a "oven too hot" fault. says to replace sensor. that wouldnt make the unit heat with out being on though
Mar 14, 2008 | Amana ACF4215 Electric Kitchen Range
Amana ACF4215 Electric Kitchen Range Logo
244 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
