Question about Denon DN-961FA CD Player
New laserunit won't work
After placing a new laser unit (KSS-240A) the cd-palyer will not play any cd's. Putting back the old laser units will let the cd player read the cd and play it, although it skips over the disc from time to time.
  • 2 more comments
  • M G Mar 14, 2008
    @Rob, I know just replacing a laser unit will not work ;-) , but after exchanging the laser unit the player does not respond whatsoever to CD's so I can not make any adjustments to the unit. The exact name is DN-961FA
    @StuartB. I have repaired a lot of these Denon cd players. I always clean the mentioned runners. This time the unit didn't respond at all. Disc spins but stops after a few seconds.
    Last week I repaired a DN-951FA and replaced the laser unit with an imitation laser, this one works fluently right after replacement. Allignment was within the manual tollerances. Just out of curiosity I placed this laser in the DN-961FA and the unit didn't worked. All allignment was correct. Replacing the old laser solved the problem, but this laser is worn out.
  • M G Mar 20, 2008
    Ok, took the DN961 again today and tried and tried again. Laserpower is OK, focus is OK. With a imitation unit the player will play discs, but with an original Sony KSS-240A laser, the unit will not work.
    I know there are lasers out there that have a short-circuit to protect the laser, couldn't find this circuit on these lasers or am I overseeing (blind ;-P) something?
    Just for the record, one player was used at a BBC station, the other came from a Dutch broadcaster.
  • Rob Galayda May 11, 2010
    OK, let me get this straight......when you place a new laser in the problem unit, the laser goes "home" to the center of the disk, the laser turns on, you get laser focus lock, you get spindle kick,the eye pattern develops, you get tracking lock and it STILL Doesnt work?....or where in the chain does it stop?
    Shout me back....Rob
    IS it possible that someone got in there before you and "optimized" the existing allignment ( I hate when people do that ) to compensate for a weak laser ?.....maybe the electrical setup is so far out that a proper laser is either blind or trying to X-ray the disk ! I would de-solder a lead to the spindle motor and see if you can get focus lock without the disk turning. Who knows, maybe somoeone replaced the motor, didn't set the spindle height and then fudged the allignment to compensate....Rob
    Oh boy...you cant just place a laser in the unit, it must be alligned.
    Allignment can consist of both mechanical and electrical. You will need an oscilloscope capable of at least 40 MHZ response and a service manual for your particular unit.
    Give me the model number and I will see what I have in the shop.
    Best of luck....rob
  • 807 Answers
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
Dvd player will not play any concert videos, says " no disk " but plays movies very well.
hi,
You have to check the laser pickup unit of you dvd player. In your dvd palyer the laser pickup unit is faulty. There are two lasers in DVD players laser unit. One for reading the DVD and the other for reading the CD. In your player the DVD laser is faulty. As it is one module you have to replace the laser pickup unit as a whole. You will get it from any electronic spare part shope near to you. As a whole i mean Normally laser pickup units come with its mechanism like in the picture . May have slight difference with your one. picture is only for reference. Its part number will be written on the bottom side of the laser unit. you have to take the laser unit as sample when you are going to buy the same. If it is reading cds it is sure that the laser pickup is faulty. Its a regular complaint to dvd palyers. To replace the laser pickup you have to remove the cd loader and have to remove connections to it.
ok
Aug 03, 2011 | JVC Televison & Video
I need one of my gemini cdj-203 cd decks fixing ! it wont read disks at all is there anywhere i could get a replacement disk drive or lazer unit ? am confidant of fitting it my self if nesseary then take...
Open the unit and look inside at the laser assembly...It should have a number on the assembly near where it plugs in...it may have a "KSS-XXX" number on it( where xxx is numbers). There is an electronics company we deal with that sells all sorts of lasers for cd/dvd unit...find this number and you can go to mcmelectronics.com to see if they carry the laser...it is very easy to install, but you will need to remember that there is an area on the new laser where they short out the laser assembly with a solder bridge( they do this to keep it safe from static discharge). You will need to remove this solder bridge before using. Replacing the laser itself is very simple...usually thewre will be a couple of rails that the laser rides on and one (or both) will come off with a clip. Simply slide the old laser off..plug in the new one...remove the solder bridge(as mentioned above)..and install the new one back on the rails.
Jan 03, 2011 | Audio Players & Recorders
Sony es cd player skips
you didn't say which "ES" model of player it is but i assume it has the KSS-240A laser pick-up, or something very similar. i've repaired so many sony cd players i've lost count and 90% of them have been down to the same fault you describe.given the age of the player the most common cause of skipping is hardened grease on the laser sled and the drive gears which causes resistance in laser movement hence the skipping. try clean as much of the old grease off the sled & drive gears as possible and relubricate. i've used a drop of light machine oil in the absence of a light grease which has made lasting repairs. but run only a small drop along the sled taking care not to drop any on the laser itself. if of course you have any light grease then i would use this but not too much. hope this helps?
Mar 18, 2009 | Sony Audio Players & Recorders
Skipping all CDs
Laser is duff uses the old sony kss family i believe,easy to change and get on ebay..
Jan 02, 2009 | Yamaha CDX-393 CD Player
PANASONIC DMR-ES35V CANNOT READ ANY NEW RECORDABLE DISCS- HAVE RESET MACHINE - TRIED TO DOWNLOAD FIRMWARE- WOULDNOT READ- PUT IN OLD AND NEW DISCS AND WILL NOT PLAY- DOES NOT RECOGNIZE NEW OR OLD DISCS.
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
Aug 14, 2008 | Panasonic Televison & Video
KSS-240A replacement/adjustment in the Sony HCD-H1700
the laser assy should come complete if its only the eye itself only loosen one slide rail and slide the old one off and the new one in this keeps the laser alignment intact .coloneus
Aug 13, 2008 | Audio Players & Recorders
Stops playing afther 1 minuit 40 seconds,saying no disc
It sounds like the disc drive is bad or corrupted. Usually in DVD-CD units if they stop playing it is a bad motor unit on the player.
Mar 07, 2008 | Philips CDC751 5-Disc CD Changer
CD player
It may be power problem/Lens cleaning
Dec 09, 2007 | Audio Players & Recorders
Does not recognise disc
Try to change the laser unitKSS-240A (opticals). In most cases problem solved. The "zik-zik" sound is made by the motors in the unit as the laser tries to read the CD.
Caution, after installing the new laserunit remove the short circuits on the laserunit itself. This it put there just to protect the laser from static energie faulure during repair.
Sep 25, 2007 | Denon DN-961FA CD Player
Denon DN-961FA CD Player Logo
670 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
