Question about Denon DN-961FA CD Player
Denon DN-961FA I do a lot of repair at Denon CD players, but this one is new to me. After changing the laserunit (KSS-240A, original Sony) the cd-player will not play any cd's. Placing the old laser (also KSS-240A) back in the unit works but sometimes skips some tracks. Anyone?
  • Rob Galayda May 11, 2010
    OOPS read your first post , didnt realize it was related to this one too.
    How does the eye pattern look?.
    Tee other question is where did you get the laser...Denon or aftermarket?
    Most of the "Aftermarket" lasers are very poor quality but have the real numbers on them.
    How is your physical allignment? Tangental allignment is OK ?
    Shout me back...Rob
2 Suggested Answers
SOURCE:
StuartB
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
I need a new transport for the cd HD 750 cd player,a better one if possible becose original makes a lot of noise thank you, George
This is what you need.This is the original Sony transport and mechanism for 750hd.
http://www.ebay.co.uk/itm/NEW-Original-SONY-KSM-213CCM-laser-lens-KSS-213C-Mechanism-and-Tray-/130593711673?pt=LH_DefaultDomain_0&hash=item1e67fde639
Oct 22, 2010 | Harman Kardon HD750 CD Player
Denon DN-600F CD player. The LINE OUT R
yes they need unsoldering from the board and new replaced if needed but you should be able to solder the ones that are already there just check for loose connection on them
Mar 25, 2010 | Audio Players & Recorders
Sony es cd player skips
you didn't say which "ES" model of player it is but i assume it has the KSS-240A laser pick-up, or something very similar. i've repaired so many sony cd players i've lost count and 90% of them have been down to the same fault you describe.given the age of the player the most common cause of skipping is hardened grease on the laser sled and the drive gears which causes resistance in laser movement hence the skipping. try clean as much of the old grease off the sled & drive gears as possible and relubricate. i've used a drop of light machine oil in the absence of a light grease which has made lasting repairs. but run only a small drop along the sled taking care not to drop any on the laser itself. if of course you have any light grease then i would use this but not too much. hope this helps?
Mar 18, 2009 | Sony Audio Players & Recorders
Need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
Dec 13, 2008 | Denon DN-1800F CD Player
KSS-240A replacement/adjustment in the Sony HCD-H1700
the laser assy should come complete if its only the eye itself only loosen one slide rail and slide the old one off and the new one in this keeps the laser alignment intact .coloneus
Aug 13, 2008 | Audio Players & Recorders
Denon 9000 Dj cd players needs a new cd drive where can i get a new drive from?
Do you need tthe entire drive or just the optics? I believe that the 9000 uses Sony optics (KSS-210). These can be purchased from a number of distributors and installed for under $100 or so.
Let me know what you intend to do.
Dan
Jun 30, 2008 | Audio Players & Recorders
Denon UD-M3 CD Receiver CD playing
Sounds like your spindle motor is shot. What happens is, the bushings in the motor that turns the CD disk are worn. So tilting the unit will change the loading of the motor shaft to an " un-worn" spot on the bushings and the CD plays properly. The spindle motors are chepa for the most part, but the labour might bite you a little because it is a fairly involved job. If the unit is still under warranty....great...if it is just off warranty, you may get some good will service from Denon......best of luck...Rob
Mar 31, 2008 | Denon DN-961FA CD Player
Mar 13, 2008 | Denon DN-961FA CD Player
Does not recognise disc
Try to change the laser unitKSS-240A (opticals). In most cases problem solved. The "zik-zik" sound is made by the motors in the unit as the laser tries to read the CD.
Caution, after installing the new laserunit remove the short circuits on the laserunit itself. This it put there just to protect the laser from static energie faulure during repair.
Sep 25, 2007 | Denon DN-961FA CD Player
Denon DN-961FA CD Player Logo
129 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
