Question about Maytag Atlantis MDG6400AW Gas Dryer
No heat We purchased the dryer in May 2004, and this is the first problem we've had. The dryer runs, but there is no heat. Not sure what to do and how to get access to the internal parts of the dryer.
  • wanna fix Apr 03, 2008
    just wondering, is your dryer fixed, did you do it yourself?  If you did pay someone, how much was it?
    thanks
  • 22 Answers
When you open the door on the dryer there are two screws on the left and right of the door opening (4) total . The front will loosen up and come forward this will expose the internal parts . do not remove the door . The door will close with the front off .
Start your dryer and look for the igniter turning on . If the the dryer is electric look for the heating element to glow. this where I would start
Posted on Aug 22, 2008
SOURCE:
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
Dryer does not heat up checked all thermostats and replaced heating element still no luck
hum... I ve seen where the motor was only getting 120 and not 240 and with most dryers they use 2 speeds or modes on the windings , 1 direction for drying with heat and the other to run minus heat thus if u only get 120 volts u have enough to run the dryer but not enough to run the heat to that dryer?
Aug 22, 2014 | Whirlpool EED4400WQ 29" Electric Dryer...
Dle5977w will not heat
Check all Thermostats and fuses. Make sure there is 220v going to dryer. Heat circuit also runs through timer and motor.
Nov 01, 2017 | Dryers
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Roper dryer res7648kq0, replaced heat element, thermal fuse, cycling thrm, thermal kit, checked outlet, circuit breaker, still not heat, will not advance on AUTO, but will on timed cycle. Now what?
Wow.
In electric dryers with an AUTO cycle; the heater runs on 220 volts, but the timer motor runs on 110 volts. There is a resistor in the system to cut down the voltage. If the resistor is bad, you will see the same symptoms as if a thermostat was bad. The timer motor will not run in the automatic cycle. You need to make sure that you test for continuity in the resistor.
I've looked at two parts diagrams for your washer and cannot find a sensor anywhere in either, so the thermostat is what tells the timer to advance once the dryer reaches a preset temperature.
The thermostat will only tell the timer to advance if the dryer reaches the proper temperature, if you have some clogging in the vents, the dryer may never reach the proper temperature, and thus not advance on the auto cycle. but i'm sure you've probably checked that. I'm baffled. Let me know how it pans out if you can. Thanks. I'm still trying to find a wiring diagram for that model.
thanks,
Mike
Jul 24, 2011 | Roper RES7646KQ Electric Dryer
Hi there, I'm hoping somebody can help me out? I have a washer/dryer and the dryer is not working. The drum rotates but does not heat up and the clothes are still very damp/wet Whilst the washer...
There are several reasons why a dryer would not heat up the clothes.
  1. The vent is plugged with lint or the blower set-screw is loose (blower slips on the motor shaft instead of spinning full speed). If you do not have good airflow at the outside exhaust when the dryer is running, you'll need to check the ductwork all the way back to the lint trap. If the lint trap is torn, repair or replace it.
  2. The heaters are not working due to a bad contact in the timer or one of the two thermostats. Check for continuity in the heater circuit with the dryer unplugged.
  3. The heaters are burned out. Note the plural - most dryers have two heaters, one for low heat, the other for medium, and both for high. Try a different heat setting and see if you get warm air. If you do, the heater you normally use is the problem.
Jul 03, 2011 | Hoover Washing Machines
Dryer runs, but does not heat on any setting
Your dryer heating element has gone bad and needs to be replaced. You can replace it if you are somewhat handy. You can purchase a heating element from your local appliance store and it will have directions that you can follow from a "handy person" perspective. However, please be sure to disconnect the dryer from its power source prior to attempting any repair. Good luck.
Feb 08, 2011 | Samsung DV218AEW Electric Dryer
Whirlpool Electric Dryer
The following link will provide with the necessary information on how to diagnose a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read the note at the bottom of the link provided, first, to determine if you have the proper voltage at the wall receptacle.
Now...if you the receptacle checks good, make sure you check the dryer vents from where it exits the back of the dryer to where it exits your home (the entire run). Additionally, make sure it is not kinked behind the dryer. A dryer needs unobstructed air flow in order to work properly and dry efficiently. NOTE: Make sure you are using semi-rigid metal type ducting. It is more resistant to heat, kinking, crushing and rodents chewing through it.
The most common failed part for a no heat problem is the thermal cut-out (TCO). If the TCO is bad, it is recommended you replace the TCO and Hi-Limit thermostat at the same time. They are often sold as a set.
I hope you find this information helpful. Let me know if you require additional assistance.
Oct 24, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
144 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
