Question about Lexmark X5470 All-In-One InkJet Printer
Scanner doesnt work
Scanner cannot download application
    Genius:
  • 2,035 Answers
Are able to make a copy if yes printer is fine : NO printer is defective ..
Posted on Mar 14, 2008
SOURCE:
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Aug 04, 2011 | Zebra Symbol Technologies MC909X-G Series...
Hello, I am with Motorola and have a MC5590. The scanner function does not appear to be working. I have version 6.5. Do you have an instruction set that can test the functionality of the scanner? Thank...
Hello Glenn,
to test the scanner I would suggest to download and install the Datawedge application. It is an desktop installation. As you will connect your MC55 to the Desktop per Active Sync the application will be installed also to your MC55.
The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, if you scan a barcode a pop-up window will come up. Or if another application is running it will send the input to the application.
Nov 08, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Acer crystal eye webcam doesnt work.
ok this problem is caused by the wrong drive installed for the Crystal Eye Web cam.
even thoguh the camera shows that it is installed, the application looks for a specific one for the model you have. Unfortunatly Acer used 3 models of the camera without telling you which you have and calls all of them "crystal eye web cam"
go to acer.com select their support section and download all driver and applications available for the camera. you will need to try then 1 at a time til you get the one that works for your system
Feb 12, 2010 | Acer Computers & Internet
I have never used my scanner yet. I am currently trying to scan 3 documents that need to be attached to an email. Help! LOL ... When I hit scan to computer it says downloading application list and doesnt...
Its looking to associate an application to itself that it can send the images to. Most all in one printers provide software for this purpose. You have to install the software that came with your unit
Oct 09, 2009 | Lexmark X3650 Printer
My pc doesnt recognise the scanner
OK.
The first thing I would try a different cable between the PC and scanner just in case it's faulty. Use a 6-foot USB) cable.
If this doesn't fix the problem:
Disconnect the scanner.
Remove the scanner driver so that we can start from scratch.
Go to http://www.mustek.com/mustek/supportdrivers.php and select your scanner model.
Download the twain driver and panel zip file.
Extract the file and install the driver
After installation, restart your system.
Once the system has restarted, reconnect the scanner.
Check the scanner icon on the control panel to make sure that it has installed successfully and that the red X is not shown.
If this does not work let me know.
May 18, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Calibration cannot be performed Error
I had the same problem when upgrading to mac os x. I was trying to scan directly from Photoshop but got the calibration message. I tried the two solutions given at the Canon website but they didn't work. I ended up downloading the Toolbox application to scan directly from there but the same message appeared. After installing the Toolbox application I unistalled the driver (11250) and reinstalled it. I opened Photoshop and tried scanning and the calibration window appeared only this time it didn't stop to give me the "Flim Adapter" warning. I must point that the scanner lid was open when this happend but I'm not sure that had anything to do with it.
So apparently it works if you have the Toolbox installed prior to installing the driver. The driver, Toolbox application and unistall driver can be found at Canon's website. Hope this helps.
Ciao!
Aug 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanner problem
try to reinstall the print management software, first.
got backup?
Feb 10, 2008 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
