Question about SanDisk Sansa m230 MP3 Player
Sansa MP3 player. songs won't show up
When I open the music folder when the player is plugged into my USB port, it shows there are about 150 songs.When I disconnect it and turn it on, only 46 songs show up. What's wrong?
Thank you!
  • Neenjaboy123 Mar 15, 2008
    My brother borrowed my mp3 6 months ago and i cant get rid of his rap music.there are only 62 song in my mp3 and when i plug it in it only shows 6. wat am i sopposed to do?
  • kjg522 Mar 23, 2008
    I have the sandisk sansa m230 mp3 player i have 104 songs on there but only 40 show up i looked everywhere and can't find the songs what is the problem? and wat would happen if i pressed the reset button on my mp3?
Are all of the songs usable types?????
Posted on Mar 25, 2008
How can I delete songs from my model m230 so I can replace with other songs?
Posted on Mar 18, 2008
Music folder is not detect
With a desktop computer and the USB cable you can transfer music to your SanDisk Sansa MP3 player. Simply hook the USB cable up to an available USB port and begin dragging music files to the folders of your SanDisk MP3 player1 Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
2 Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
3 Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player's memory are displayed.
4 Open a folder containing music files that is stored in your desktop computer's memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
5 Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
6 Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Nov 19, 2011 | SanDisk Sansa E280 MP3 Player
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
I can not resync my sansa e270 when i plug it into the computer, i use rhapsody and never had this problem before
Hi, theres 2 ways usually to sync with sansa.
usually wen u plug it into the usb cord, u shud be able to open a folder and put musik through that.
My computers. than go to Sansa
or WMP depending on ur version
go to Synchronizing or Copy to CD or DEVICE.
there should be syncing button under the music list depending on the version.
but i stick to open my computer and the Sansa folder.
IF NOT THAN DO THIS..
Go to ur Sansa in the USB option change it to MSC than follow these instructions
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the drive for your Sansa.
3. click on Tools choose File Option, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
Good luck.
Mar 12, 2011 | SanDisk Sansa e270 MP3 Player
How do i delete all the songs off my sansa e260?
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselfs then format a couple of times hope this works
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer2.gif first
Dec 20, 2010 | SanDisk Sansa e260 MP3 Player
Sansa Clip 2GB MP3 player
The user manual wil lshow you how to switch your USB mode from MSC to MTP:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB* MP3 Player
Switch the player from USB to either Auto or MTP mode. Or, you can transfer ALL songs in the manner you have just described. Either way.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Feb 10, 2008 | SanDisk Sansa E280 MP3 Player
Deleting songs
If you want to delete songs off your Sansa you just need to go to "MY COMPUTER: And find the sansa drive open it then look for the music folder.If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files> you should now see the music file. Go into it and simply delete any songs you don't want.
Oct 19, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
