Question about Clarion DC625 6-Disc CD Changer
Old clarion 1998 cd changer
I have a old cd changer i hooked up in my girls car but when i turn it on a meesage reads error 7 what does this mean
  • ill will Mar 13, 2008
    please help
  • 199 Answers
What head unit is it and what changer are you useing?
Posted on Sep 29, 2008
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Office Equipment & Supplies
My cd stacker comes up wit erorr 2 on the screen the car battery was replaced dose it need a code
in many of these changers error 2 means there is a cd stuck in the player, inserting an empty magazine for it to slid into often helps
Jan 12, 2015 | Clarion UC 6 CD Changer
Rd634 clarion changer error code 9
two reasons one if you are recording a disk the error is because the disk may be scratched so you must cycle off the power and try a new disk if your not trying to record a disk error code 9 also means and this is taken directly from the manual..
There is a problem with the FM Modulator circuit.
Contact your authorized Clarion dealer for repair.
i hope this helps
Mar 14, 2011 | Clarion Car Audio & Video
Clarion 12 Disc CD Changer Model # CDC 1255z What
out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
Jun 12, 2010 | Clarion CDC1255z 12-Disc CD Changer
Error 3
plug of car battery for 5 minutes then reconnected again with switch of CD player .
Nov 24, 2009 | Clarion DXZ665MP CD Player
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Jun 12, 2008 | Clarion Car Audio & Video
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jun 18, 2017 | Clarion ARX9270
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
Clarion RDC634 Error 9
First thing to suspect would be the antenna cable or antenna. Check it is connected properly to the back of the unit, and check the cable all the way along to the antenna - these are prone to internal corrosion when they get a bit old. Easiest way to check is to get a new antenna and cable (they are cheap) and plug it in directly to the back of the unit. Check the ground connection of the unit is good - any terminals might need a clean up - disconnect the battery first. These guys have a service manual for sale; http://www.user-manuals.com/advanced_search_result.php?keywords=Clarion+RDC634+manual&forward=plist&osCsid=64c58306e0b8605abe537ef57684dcc0 so do these; http://www.manualscenter.com/allprod-42-217.html here's the link for a free download of the owner's manual (it says is for the 635, but is also for the 634); http://safemanuals.com/user_guide_instructions_owner_manual_CLARION_CDC635%20OWNER%27S%20MANUAL_E.htm Hope this helps :)
Jul 07, 2007 | Clarion DC625 6-Disc CD Changer
Clarion DC625 6-Disc CD Changer Logo
244 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
