Question about Kitchen Ranges
Rust on stainless handle charbroil - Kitchen Ranges
  • richson Mar 13, 2008
    its a outdoor grill
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Stainless steel ??? rust??? technically s/s should never rust. however particles on the finish will rust and stain the metal. heres a solution that i use and works real well. look closely at the handle you should be able to detect a grain in the metal ( just like wood s/s has a grain pattern) with a scotchbrite pad sprayed with wd-40, wipe handle WITH the grain, slowly at first applying even long strokes,, it will come clean, as well as leave a protective finish so as not to happen again
Posted on Mar 14, 2008
Should my blade have started to rust as I thought they were stainless steel?
Stainless steel does rust... titanium doesn't. You should wash and promptly dry the cutter blades with a cloth after each use to prevent rust which will dull the blades must faster. (Pleasure boats use stainless steel bolts and fittings throughout, and they are always slightly corroded.)
Apr 04, 2015 | Food Processors
How do youbget rust off a knife blade
If it has rust on it it is not 440 stainless as 449 stainless does not rust.
Oct 21, 2014 | Sport & Outdoor - Others
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
Seyer will not stop when trigger is released
THERE IS A SPRING IN THE HANDLE, IT DOES RUST. CLEAN THE HANDLE AND GET A STAINLESS STEEL SPRING FROM THE HARDWARE STORE / TOOL SUPPLY SHOP. also THE PRESSURE SWITCH CAN CLOG AND THAT SPRING ALSO RUSTS. CLEAN AND REPLACE, I DID AND IT WORKS.
Nov 07, 2013 | Garden
How do I start the fire?
It's really not difficult, but must be done safely. I assume you may have misplaced the Owners Manual, so I have provided a link to it, that you can download and print for future reference. As you read over the Owners Manual, you will note, that starting on page 7, the instructions for lighting and using your grill safely and successfully, start there.
This may not be the same exact model you have, as Charbroil makes 2- Commercaial Stainless Steel models. But, they operate the same way.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247311%20english_80dfc074-6_.pdf
Hope this helps you enjoy your gas grilling experience. Happy Grilling!!
May 12, 2011 | Char-Broil Commercial Stainless Steel...
Need P/n for 2 Stainless Steel doors for Charbroil Model 46322000
Im not sure where to go for parts but We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff will remove the rust and truely clean your surface.
Feb 05, 2009 | Char-Broil 463220004 Grill
Food keeps sticking to my grill,and it keeps rusting.
you dont have the temp hot enough before placing the food on the grill the rust is from exposurwe to the elements
Jun 20, 2008 | Char-Broil CharBroil 4637318 Grill
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Kitchen Ranges Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
