Question about Uniden DXI4286-2 Cordless Phone (DXI42862)
Phone keeps ringing after I answer it.
It just keeps ringing after I answer it. I have 2 other land phones and this does not happen with them, just the 2 Unidens.
5 Suggested Answers
  • 201 Answers
SOURCE: only 1 phone rings
There is a small battery inside your main control unit that keeps programming in memory during a power outage. The life of the battery is about 5 years give or take. When the system goes down for an extended period (or possibly several quick on/off cycles) your programming will be wiped out. By default, only a few telephones will ring. The battery is most likely a small blue 3-cell battery soldered right on the main board. It's not easily replaced. You can get a technician to replace it or hook up a standard battery backup unit (UPS) made for a computer. Your phone system uses less power than a computer so it can use any UPS and will last longer than advertised. Hard to say exactly how long. Just don't re-program the system until you take care of the problem or it will just default on you again.
Posted on Jul 05, 2007
SOURCE: speaker problems for sony ericsson 905 mobile
My phone which is 2 months old has incurred the same problem today! I took it back to the carphone warehouse and they are sending it away to be investigated. However a friend of mine wanted the identical phone and by coincidence went into the o2 shop today to upgrade and was told there was a callback on them and none available until further notice! There must be some sort of fault on the handset and probably this is 1 of them.
Posted on Jan 07, 2009
  • 14 Answers
SOURCE: HOW CAN I ANSWER THE PHONE WITHOUT PRESSING ANY BUTTON?
It has to do with a program called ringing line preference. Program # 4-11. Check out www.wedophones.com/Manuals/NEC/Electra%20Elite%20IPK%20Programming%20Manual%20-%20Document%20R%204.pdf
If you happen to have an Electra Elite 48, 192 or IPK this manual can show you how to program that feature. Don't take it lightly though, you can jeopardize your system if you do not know what you are doing.
Posted on Nov 11, 2009
SOURCE: the phone rings once, then stops ringing
Remember to also disconnect direct tv receivers. I had the same problem untill I unplugged them from the phone line.
Posted on Oct 29, 2010
My Panasonic modelKX-TGA410c with all in coming calls all I get is one ring. I dont know how to see if there is any way of checking or increasing the rings.
That is the model number for the phone handset. You need the manual for the base unit if it it has a voicemail facility. However, it is mention on Page 35 how to set anything between 2 and 7 rings.
Number of rings before the unit answers a call You can change the number of times the phone rings "Ring count" before the unit answers calls. You can select 2 to 7 rings, or "Toll saver". The default setting is "4 rings". "Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call
ftp://ftp.panasonic.com/telephone/om/kx-tg4132_mul_om.pdf
Jul 19, 2018 | Panasonic Lands Phones
Why do I get an average of 1 or 2 single-ring calls on my land line every day?
This is a telemarketer trick. If you answer on the first ring, they have you hooked for the pitch. More than one ring indicates to the autodialer that no one is home and to move on to the next "prospect".
Apr 18, 2018 | Lands Phones
How can i limit the number of rings before the answering machine kicks in on my panasonic 6.0 phone
Answering system settings Number of rings before the unit answers calls You can change the number of times the phone rings "Ring count" before the unit answers calls. You can select 2 to 7 rings, or "Toll saver". The default setting is "4". "Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages , you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. 1 {MENU} i {#}{2}{1}{1} 2 {V}/{^}: Select the desired setting. i {Save} i {OFF}
Jan 17, 2018 | Panasonic Lands Phones
When I get a call and I am not home my phone keeps ringing. No one can leave a message.
Do you have an answering machine, or an answering service affiliated with your phone service?
May 12, 2017 | Lands Phones
Increase number of rings from 14
The number of rings is controlled by the answering machine, not the phone. What make and model answering machine do you have on your phone line?
Oct 30, 2013 | Uniden Cordless Phone
Uniden 6.0 phone keeps flashing incoming call but there is no call
press menu
scroll down until you get global settings
press menu
scroll down to vmwi reset press menu
scroll to yes
press menu
then press end
write this down as it will continually happen
Dec 06, 2017 | Uniden DECT 6.0 Cordless Phone ID
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
Dec 05, 2007 | AT&T 1738 Digital Answering Machine
Uniden DXI4286-2 Cordless Phone (DXI42862) Logo
179 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
