Question about Midland 1001Z 40-Channels Base CB Radio
Transmitting Squeal I receive signals very crisp and clear on all channels. However when I key the mic, whoever is receiving my signal, hears a very loud mono tone squeal. None of the controls have any affect on the noise, yet when I move the mic around in the cabin, the squeal changes tone. Also when I wrap my hand around the mic cord at the top where the coils begin, the squeal goes away, the digital power meter goes into the red, and I transmit just fine. I am using: New Midland 1001Z radio, original stock mic that came with the unit, 3 ft adjustable Firestik antenna and a Hood Channel Mount kit that includes 18 feet of Fire-Flex coaxial cable with the Fire-Ring connector. I have the power connected to the fuse block under the hood and ran through the firewall using the supplied rubber grommet. I kept the ground wire short and found a nice ground near the steering arm. I have heard that shortening the coax cable affects the whole system so I kept it at the stock length. However since I am short on room, the excess slack is coiled up and stored behind a dash panel. My guess for my problem is either the coiled up coax, the coax running along the hood channel, or bad grounding. If it is a bad ground, how would I check for a solid ground? Also the antenna and mounting kit does not mention anything about grounding the antenna, do I need to do that with my set up? (See picture above) If so, how? Thanks for your help!
  • 1 more comment
  • Rouge 2 Mar 15, 2008
    I have deduced it is not the coiled up excess coax. The noise now goes away if the antenna or coax cable is touched by a human while the mic is keyed. Hopefully this helps narrow down my problem for someone.
  • Dean Pitts
    Dean Pitts May 11, 2010
    Please use your radio and mic with another persons antenna and coax setup, in their vehicle. That will be a good starting point. After you do that, please reply back here or at my email:
    rollincbmods@yahoo.com
    I would be more than happy to try and help you figure this out.
    Dean Pitts
    Rollin CBs
    Mt. Vernon, TX
  • Dean Pitts
    First of, do you have anyone you know with a good radio and mic? If so, you can check your antenna setup with it to eliminate that from the equation. If you can do this, please reply with the result, so we can go forward.
  • 3 Answers
Power right off the battery
Posted on Sep 03, 2008
5 Suggested Answers
  • 39 Answers
SOURCE: midland squealing when talking
soundwas keying up at the same time.s like it could be one of two problems. a loose wire in the mic or some one near you keyed up the same time as you. if the wire in the mic is loose sodder it. If some one keyed up near you you might have blown the reciever chip.
Posted on Oct 06, 2008
SOURCE: CB Squeal When Transmitting
I believe the coiled coax may indeed be the problem. To check, try a temporary rerouting of the cable which eliminates the coils. Dave g.
Posted on Jan 08, 2009
I replaced the radio, my problem went away..
Posted on Mar 24, 2009
vortash
  • 431 Answers
SOURCE: Midland 1001Z Channels
Hi yes it is possible as is anything if your willing to pay for the conversion , it would require new chrystals and resetting of the If system but is possible . However porobably not economical Midland did do The 100 model in an Fm modulation format and you will probably find still available on Ebay or Amazon if not that paticular one a good version at any rate ..I beleive they did actually do an Am Fm model also ...Regards Vortash
Posted on May 11, 2009
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
I have 2AKG UHFHT40ULTRA HIGH FREQUENCY handheld transmitter microphone , why when I turn them on they blink on and then notning ?
Okay, before going any further, let's just check....
  1. Along with your wireless mics, you have an AKG wireless receivers (e.g. WMS40 mini2), right?
  2. You've checked that mics and the receiver all work on the same frequency?
  3. You have connected both outputs from the WMS40 mini2 to individual mic channels on a mixing console?
Let's recap....
  • The AKG mics aren't going to work unless you have one of the matching receivers
  • The receiver has to be the correct type. This means if you want to run two mics at the same time, then you need a dual channel receiver (WMS40 mini2) otherwise they'll block each other. So, if you only have a single channel receiver (WMS40 mini) then you can only run one mic at a time, not two.
  • The mics and receiver have to be on the same frequency. They make it easy by colour coding the hand mics and the receiver. If the colours are different then they're working on different frequencies that are not compatible.
If you're good to go on all the above then the next stage is just the connection and set-up of the mics, receiver and mixer.
Since the mics are a pretty straightforward On/Off switch affair then there's not much to say there. Just make sure you maintain the correct distance for to ensure the wireless signal spreads out properly. It needs a minimum of 3m (about 10ft) distance between the mic and the receiver.
The receiver is straightforward too. It needs power, so make sure you plug in the mains adapter. The front LEDs give you the status of the signal. There's only two lights per channel, so it's easy to understand. RF OK confirms that the receiver is picking up the mic signal, so this one should be lit. AF CLIP let's you know when there's too much level from the singer/speaker. This could be that the receiver's volume control is set too high, or the singer/speaker is holding the mic too close for the volume they're producing.
The receiver's volume control needs to be adjusted fully counter clock-wise if connecting to a mixer by a balanced audio connection. If you're running in to the line level input, then the dial needs to be turned fully clock-wise.
The signal connection going to the desk should really be made with balanced leads. Jack to jack (TRS) or jack to 3 pin XLR will both maintain the noise suppression benefits of the balanced audio connection.
The rest is how you set up the mixer for the signal. Good luck.
Sep 14, 2014 | Audio Players & Recorders
Senheiser freeport no sound
If it seems as though the transmitter signal is being received but there is no audio, disconnect the 3 or 4 pin connector of the mic and touch the different pins while transmitting to the receiver. If there is audio hum or buzz, the mic itself is probably dead. A wire could be off inside its connector.
Mar 04, 2014 | Sennheiser Audio Players & Recorders
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
Dec 20, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Grounding the antenna bracket is extremely important, if it's bolted into the metal frame or fender it should be OK. The coiled coax cable could be the culprit but that's only a remote possibility.Try running a separate groung wire from the radio mounting bracket (or one of the radio's cover screws if not using a bracket) to the CLOSEST vehicle ground...keep this a short as possible. Your problem is definitely caused by insufficient ground at either end of the coax, with the antenna side being more suspect.
Mar 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
Cant hear
Several things can cause poor reception. I have a few questions for you.
1. Have you tried measuring your SWR (standing wave ratio)? This helps give you an idea how well your transmission line and antenna are working.
2. Is this radio being used as a base or mobile? Do you have proper grounding on the antenna?
3. Pressing the mic button and seeing the radio indicate "transmit" does not always mean you are transmitting at full rated power. Have you tried transmitting through a wattmetter into a dummy load?
4. If the transmission line is good and the antenna is good, then I would suspect that something may be wrond with the receiver's front-end (sensitivity).
Receiver sensitivity can be checked by using a RF signal generator. Unfortunately you'll have to take the unit to a repair shop to have that checked. Try the other things I mentioned above. Let me know what you find and we'll go from there.
Good luck,
- Jim
Jan 28, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
260 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
