Question about Epson Stylus Color 760 InkJet Printer
Epson 760 Problem
I was just finished succesfully printing mailing labels on my old 760 and noticed that all of the lights suddenly began blinking. The manual says that this indicates that there is "an internal error" and that it needs service. Short of looking for a new printer, is there anything I can try to rectify this problem? I've tried the usual routine of shutting down the computer, re-starting, etc. but pressing the ON/OFF button doesn't respond. Any suggestions? Bill I have exactle the same problem. Help please
  • Anonymous May 22, 2008
    All 4 lights are flashing, when I press the on/off switch to turn it off, nothing happens. I bought the printer in December 2000. The only way to turn the lights off is to pull the plug or turn rthe power off.I have tried turning the printer off and then turning it back on some time later but as soon as the power comes on the lights flash again
  • fzs1000 Apr 27, 2009
    Top man this did the trick
    Thought that i had to buy a new printer, you saved me money.
    Thanks Doug
I found this procedure to work for the Epson Stylus 760 printer. The error is indicated by all four lights on the printer flashing and appears to be caused by the internal counters of the machine being exceeded. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
1) Turn off your printer, ensuring that the print head is at its home location and locked in place as normal.
2) Remove the four screws securing the top cover two at the rear and two at the front under the lift up cover and lift the cover off.
3) Remove both ink cartridges.
4) When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1.
5) Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down.
6) When the paper-out LED flashes, release the buttons.
7) Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button).
8) The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
9) Insert the cartridges as normal and replace the cover.
Posted on Mar 30, 2008
  • CIFIX Nov 01, 2009
    These are the two buttons on the front of the printer other than the power on/off switch
Which wone cleaning button Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button
Posted on Aug 09, 2010
I had a similar problem where all the lights were flashing and kept on flashing even after turning off the printers power switch !
Pleased to say that solution 2 resolved my problem and all is well again with this workhorse !
Cheers! Alan.
Posted on Jul 21, 2009
The 'buttons' are not obvious to me - where are they?
Edsl8er
Posted on Jul 01, 2009
Worked a treat. Funeral posponed
Posted on Aug 27, 2008
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
All 4 lights flashing
Probably the waste ink tank is full.Try this:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
Nov 11, 2009 | Epson Stylus Color 760 InkJet Printer
All 4 lights blinking
I cannot get ink printer out as it stuck in Epson Stylus color 760. I have been clean and extract waste leak ink away. The light is still blink. Sigh
Apr 09, 2009 | Epson Stylus Color 760 InkJet Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Pause light blinking, machine beeping, no printing
Probably needs a good cleaning - with a vaccuum and some compressed air.
Dot matrix (impact) printers usually have a couple of optical sensors - disks with holes in them - to let the printer know where the head is, how fast it's moving, if it jams, etc.
If there is too much dust, dirt, or bits of paper interfering with the beam of light passing through the rotating disks, most printers will stop and indicate some sort of error, rather than force the motor - which may damage the plastic teeth on the gears.
Sep 16, 2008 | Epson LQ 570+ Matrix Printer
Epson c66 will not print black
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Jan 13, 2008 | Epson Stylus C66 Inkjet Printer
PRINTER LIGHTS BLINKING RED THEN GREEN
Either you have ran out of an ink, because some epsons wont run until you replace cartridge, you have a document pending a print, or you need to disconnect printer, uninstall drivers from Add/emove programmes. Re-install driver then re connect printer when prompted
Nov 10, 2006 | Epson Stylus Color 760 InkJet Printer
Epson Stylus Color 760 InkJet Printer Logo
423 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
