Question about SanDisk Sansa m250 MP3 Player
Sansa m250 won't finish "finalizing update"
I got a sansa m250 for Christmas. My sister has had one and it work great. She got songs on there easily and it works fine. Does the device work with iTunes? Because I gave it to my boyfriend to put songs on there. I showed him how the mp3 player worked and everything. He went to put songs on there a week ago and it is still "finalizing update." I have tried plugging it into the computer, but my computer doesn't even mention that it's plugged in. I've tried replacing the battery and everything. I really don't know what to do.
  • TCSchmitt Mar 29, 2008
    so how do i get it to stop "finalizing the update" because right now i can't do anything with it. i've tried to connect it to the computer and my computer doesn't register that it's connected. is it just my computer??
  • Stormy2 Apr 05, 2008
    Got the same problem, and it seems to be a common one.
    It seems the unit has some trouble reading certain mp3 files and freezes.
    I couldn't find a total reset button, which presumably would have solved the problem.
    Bad software.
De ce nu se copntecteaza BeraShear la internet?
Posted on Oct 14, 2010
I had the same problem with my m250, the PC wasn't recognizing the device nor the connection. So I tried the settings of the mp3. I started by going to the menu, then settings, then USB and then selected MSC instead of Auto Detect. After that, my PC did recognized the device. Hope this helps.
Posted on May 06, 2008
I got sansa M250 players as gift from my frnd.i had a small problem with this,as i connect this to my PC its not recognizing as a drive or a connection .Earlier i thought there is a problem with my PC but i connected my my player to my frnds PC and still its not identified . Whats the problem with this how can i get rid of this state .
Posted on Apr 08, 2008
  • 66 Answers
Ummmmm.... What are you doing exactly if your trying to download the music, Download using limewire, bearshare,
Its not going to work on Itunes most of the time so just use Limewire or bearshare. Connect the Mp3 using the Usb thing and try to put it in front of the cpu or behind either 1 of them.
After you should probably get a pop up scroll down and go to view folders or whatever and open it and put the music you want in the mp3 and when yur done beside the clock look for a Safetly USB remover or whatever and disconnect it.
I hope it works
Give me some Credit
and click the Button XD
Posted on Mar 28, 2008
  • Brandon Tran
    Brandon Tran Mar 29, 2008
    Try connecting it to another computer, if it works then you just have to use that computer to download music onto the MP3.
    If it doesn't work on atleast 2 computers then its the USB.
    If it doesn't work try connecting the USB to another USB port around your computer their should be atleast 2.
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
SansaDisk Sansa m250 (2GB) "Finalizing update"
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Jul 20, 2010 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
What Can I do if My Mp3 sansa m250 froze
This is an ongoing issue and its better that you called Sandisk about this to have it replaced under warranty.
Jun 17, 2008 | SanDisk Sansa m250 MP3 Player
Sir My sandisc has been forzen saying its Finalizing update
the software may have got corrupted.
better get it reprogrammed to bring it back to working condition
Sansa m250 2GB file adding problems
Can't create directories directly on the m250. I've got about 1000 songs loaded (already broken into subdirectories) that take up 800 MB and the device claims that it's full. (Firmware is also updated to 4.1.08A)
Dec 26, 2007 | SanDisk Sansa m250 MP3 Player
Please wait rebuilding the library. Then the m250 shuts off.
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 19, 2007 | SanDisk Sansa m250 MP3 Player
Frozen
Mine froze in play position, but no sound.
Here's what worked for me. Mine is the Sansa M250
1)Plugged the player into the PC and removed all the MP3s
2)Downloaded update program from Sansa link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
3) Install the program
4) Plug the Sansa into your PC.
5) Program automatically starts and allows you to check for software update. Do so and let the program update your player.
Fixed my freeze problem. Player working perfectly now.
Hope this helps.
Dec 05, 2007 | SanDisk Sansa m250 MP3 Player
My directory where MP3 are stored in sansa m250 cannot be seen on the desktop
Gagan, Please see my answer here http://www.fixya.com/support/t149468-san_disk Formatting your Sansa should do it. Let me know if it didn't and please rank my answer. Thanks, D.
Jun 16, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
613 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
