Question about Proview PL926WBi 19" LCD Monitor
Monitor wont stay on
Screen gose black. i push the off button then push it again it comes on for about 3 or 4 seconds then gose off again. every time i turn it off and on
  • Anonymous Mar 18, 2008
    Imhaving exactly the same problem with mine & mine is exactly a year old to the day!! Will try this solution & post back as to how I got on.
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPUmonitor wont stay on - 1.gif and monitor. After it goes off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Posted on Mar 14, 2008
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
Frozen
press the MIDDLE BUTTON and MENU button at the same time
or
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
Monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
May 30, 2009 | Acer X193W LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
My microtek 517m lcd monitor it keeps going blank
the monitor its self has no problem but try installing the drivers again
Feb 06, 2009 | Black Box Computers & Internet
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Robert
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
71 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
