BACKUP ERROR, NO DISK SPACE.......SAYS TO FREE UP DISK??? THOUGHT EACH MONTH IT OVERWROTE PREVIOUS FILES ??????????? HELP
    President:
  • 2,351 Answers
Some back-up programs will over write. If they do you'll need to check the settings & turn that part on. If your does not, keep only the last three if you have the space.
Posted on Mar 13, 2008
SOURCE:
How to cope with Laptop C partition low disk space error problem
Hi Belinda
Basically it is a good idea to use the "C" drive for the Operating System (Windows) and minimal 3rd party software.
Move all Movies, Music & Photo's to another drive. The "D" drive.
This can be internal or external depending on the computer.
An external 1 to 4 Terrabyte drive on the USB port is really useful actually... it is really mandatory these days to perform backups & keep the big files on. Like Movies & Music & Photos.
To give you long lasting capabilities into the future I would suggest something like this Dock Drive
http://eshop.macsales.com/shop/NewerTech/Voyager/Hard_Drive_Dock
You get to choose which drive to plug in and they can be stored securely (in tinfoil antistatic) when not in use.
The dock will allow you to keep a bootable emergency drive on one drive and a backup of all your movies on another and even a copy of all your music on another. This is my preferred method as it's future proof. if your computer gets broken or stolen then you still have a copy of everything. I prefer to use the 3.5 inch (larger) drive as they have faster access & backup capability. The 2.5" drives are great for portability & run on 5volts only so are not as fast. The dock can take either.
Hope this Helps
Nov 27, 2014 | Computers & Internet
Dell studio low memory
Low memory problems could be low virtual (hard disk) memory.
Hard disk maintenance will free up hard disk memory space.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Jan 04, 2013 | Dell Computers & Internet
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
I have a 250 GB my passport external Hard drive. I used XCopy to backup some of my data. After several hours, it gave me an error that the disk is full and it cannot copy, and aborted the task. I had 165GB...
open the Drive and go to Tools--->Options and Click on 'Show Hidden Files'
Click on 'Apply' and the 'OK'
Now look for the files.
Also i feel that the disk is infected. So please scan the disk through a antivirus software.
Aug 01, 2011 | Western Digital My Book Essential Edition...
Here we go.My backup to D drive crashes after about 950M.It used to go all the way through to around 3.3 G.After they finished,I would go back and erase the previous backup to maintain space on my D...
Hello Greg!
As with most Backups, the method and software doing the backup are key.
Backups will not function if you are trying to back up open files or programs; unless Volume Shadow Copies is turned on, and your Backup Software can backup from those.
Another hurdle could be that you have decided to backup files that are locked by Windows as long as you are logged in to your Profile. A reboot and log in as Administrator would free up those locks,
Can you help us understand what you are backing up with and which files?
Mar 16, 2017 | Dell Studio Slim PC Desktop
I can't backup files, because it says I have no more room. How can I fix this?
Delete some files or backups. If your backups are appending or creating a new file every time without replacing the old ones, it will eventually fill up.
If the drive is not full, it may be your file system. If the partition is formatted FAT32, you have a maximum file size of 4 GB. The backup will proceed until the file size reaches 4 GB, then it will close out and the rest of the files will not be backed up.
Using Disk Management, you can create a new partition, this tiime NTFS. Unfortunately, you'll lose all files on the drive when you partition so you'll need a place to move the files to temporarily.
Aug 08, 2009 | Seagate Maxtor OneTouch 4 500 GB USB Hard...
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Is the drive formatted as FAT32?
If so, and your backup is more than 4GB, it will not be able to write the file to the drive.
Open a Command Prompt (Start | Run | CMD) and at the prompt type:
CONVERT V: /FS:NTFS /X
Where V: is the drive letter of your My Book.
That will convert it to NTFS and it will be able to handle files larger than 4GB.
Apr 28, 2008 | Western Digital My Book Essential Edition...
Open Questions:
Computers & Internet Logo
27 people viewed this question
Ekse
Marvin
Marvin
