this is most likely a safety switch on heat element has tripped/went bad , this tiny device keeps heater from causing a fire if heater gets to hot , common cause of this tripping is a blocked vent pipe
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
clean exhaust vent ASAP it could start a fire if the heat has nowhere to go out the moisture stays inside and your heat element will cycle on and off on a high temp limit swich
I have a Whirlpool dryer with LP gas, 7 1/2 years old. It will fire up once or twice after started then the next time it is supposed to fire it will make a buzzing sound. No heat. It will not produce heat after this until it sits for awhile then the same thing, will fire once or twice then no more. I replaced the ignitor and this did not solve the problem although it did have a consistent firing for about 3 minutes immediately after I replaced the part. then it started buzzing again and would not fire anymore. The propane line doesn't appear to be the problem either since it will work initially. Also the gas water heater in the house works fine.
Why did it go in the shop anyways?Was it being painted?Ive never removed a dryer to repair it un less it was to be painted.What are you saying about red hot coil?If this is a 220Volt dryer than yes the coils get red hot,thats normal.The repairman is most likely responsible if it caught fire in any way!Sounds un believable to me.
