Question about Canon imageRUNNER 2200
Printer problem our company got a second hand printer from other place and I am going to set up it as network printer. I set up static IP and installed driver on our printer server. then I try ping the printer from either server or workstation, it seems it is working. I try print some test page, it didn't go through. no error messeage, you can see the processing light is on and flashing and then nothing come out. it is really weird. we install the nic . any idea
  • 38 Answers
Along with the nic, there is a DIMM that also needs to be installed. In addition to this you also need to upgrade the firmware of the machine to convert it from a copier to copier/printer.
The easiest way to check this is to go the additional functions menu > system settings > network settings.
Once in this menu you should look for a menu named "Netware". if the netware menu is not there, then either the DIMM has not been installed, or the firmware has not been upgraded, or both. In this case you won't be able to print unless you do the afore mentioned.
From here the easiest and cheapest way to proceed is to update the firmware to convert the machine to a copier/printer. This should be done by a Canon technician.
If this download fails, then the DIMM has not been installed either. All you can do in this case is source somewhere that you can buy this DIMM and get a technician to install it and update the firmware.
Have Fun with this one
Posted on May 08, 2008
Need ip address for DI3010f
Your network determines that! To load your IP address once you have it go 1. Admin Management 2.Admin Settings #2 3. Network Settings, 3. Network Settings #1 Basic Setting and then place IP address Gateway and Mask. RECOMMEND YOU USE static IP not DHCP which then the sever determines your copier IP Not good
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 03, 2014 | Minolta Di3010f Printer
Canon imageRUNNER C3200 Copier network setup parameter needed
Are you talking about creating a printer port in Windows to print to?
You can use a normal RAW 9100 port (just choose custom, and it will set it at that)
But I suggest setting the copier with a static IP.
By leaving it to DHCP, if you set any machine to use that address, if if "flops around" you'll lose the pointers to that address. Just go into the web interface on the copier to set the static IP.
Your question was just slightly confusing to read. I hope that's what you are asking for.
Aug 12, 2008 | Canon imageRUNNER C3200 Copier
Try to connect the hp laserjet 8000 to network, since we connected with static ip, how could I change to dynamic ip?
First, why would you want a printer with a dynamic address? Do you have one reserved in the dhcp scope for it? Do you have the printer named in DNS? Printers are much easier to deal with when they have a static address, they're always in the same place on the network.
All that said, browse through the menus till you find the network setup find the IP menu and set it to automatic. Very simple. Make sure to save your configuration change.
Oct 24, 2013 | HP LaserJet 8000 Printer
I have a HP C5180 all-in-one printer connected to a Network. It keeps changing the IP address AND going offline on it's own. I can change the IP address to what the network says it is, but I can't figure...
You can set Static IP address according to your network
When you will press the Setup Menu and go to Network Menu You will find an option which says Ip address there you can assign Static IP address
Once done that may be your printer will go offline again and you can set it online by right clicking on the printer and selecting "Set Printer Online" option (Assuming you have Windows OS
Jan 11, 2011 | HP Photosmart C5180 All-In-One InkJet...
My network printer not taking ipadress as i have provided static ip through laptop.is there any settings in printer to add ip address . thanks , kalyan
First, make sure you have plugged in a network cable CAT5 or CAT6 into the printer's network card (if you don't have one, then you can't use it as a network printer). Also, the network cable should go to a switch, hub or router.
Second, the IP address needs to be set on the printer, not through laptop. You should browse to the menus of the printer, until you find a menu Network, under this menu you should have TCP/IP sub-menu where you need to set the IP address, also there must be a Subnet Mask sub-menu and a Gateway sub-menu. This two options should be set up as well.
Nov 23, 2010 | HP LaserJet 4250n Printer
I am unable to reset the admin password on a company printer HP laserjet p2015dn. I treid doing a cold reset by holding the go button while restarting the printer for about 10 seconds and the configuration...
Try to change the password over the network by tyoing the assigned IP address into your browser URL. If you can see the P2015, you should ba able to find the place to change or disable the admin password. If not, perform a Super NVRAM Initialzation:
  1. Turn off the HP Laserjet P2015 Printer.
  2. Press and hold the Go button.
  3. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention, Ready, Go lights turn on. Then the Attention and Ready lights turn off,leaving only the Go light illuminated.
  4. Release the Go button. The Go, Ready and Attention lights turn on.
  5. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
  6. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
May 02, 2010 | HP LaserJet P2015dn Printer
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Mar 02, 2009 | Brother MFC 6490CW InkJet Printer
About n/w printer
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
Sep 16, 2008 | HP LaserJet 1022 Printer
HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Aug 18, 2008 | HP LaserJet P2015n Printer
Canon imageRUNNER 2200 Logo
60 people viewed this question
old marine
old marine
