Question about Refrigerators
Fridge adjustable height?
Can I adjust the height of Maytag Plus MSD2456DE side-by side-refrigerator? Are the wheels adjustable?
  • brentj Nov 27, 2008
    I too have a Maytag side-by-side that I need to adjust as it sits too low in the front. I don't know how to lower the front wheels down to lift the firdge...any advice?
    Novelist:
  • 87 Answers
No.
Posted on Mar 13, 2008
Are back feet/rollers adjustable?
normally the rear are just rollers
for your problem use tapered door wedges ( hardware shop) under the appropriate side at the rear of the fridge to make the adjustment
Sep 04, 2017 | Electrolux EI23BC51IS
How do i stabalize the fridge
Look at the feet on the fridge. You should be able to turn them in or out to adjust.
Jun 21, 2011 | Refrigerators
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
My maytag refrigerator has wheels both back and front. The front wheels are bigger and the back wheels are smaller and they have screws holding them. The back of the refrigerator is a little lower than...
Look behind the grille in the front bottom of the fridge... there are adjusting bolts there to adjsut the height of the front and back wheels to level it...
heatman101
Aug 26, 2010 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator is not cooling-what can I check? It is a Maytag Plus Model MSD2456DE*
the first and main component to check is the compressor the black paint shape in the back of the ref. then the thermostat check also the relay close to the comressor.
Jul 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Apr 04, 2009 | Refrigerators
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Wheel adjustment on a ge fridge
if you take the front kick plate off by pulling on it. once the front kick plate at the bottom of refrig. is off bend down and you will see 1 bolt head that looks bigger than the rest of them. 1 on each side of the refrig. now if you need to lower the refrig turn to the left. to raise turn to the right. this do it for you. thanks eddy
Jan 03, 2009 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerators Logo
842 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
