I have digi design 001 and I keep getting dae error 9073 on my protools
  • 73 Answers
For those hitting the -9073's, a couple of urgent needs:
1. Please explain what Editing functions you are performing that cause -9073's. BESIDES creating fades, Audiosuite, Consolidating, or TCE Trim (as these all fire off background disk-writing processes, which we've confirmed can indeed cause -9073s.)
2. Open up Task Manager and keep an eye on it to perhaps catch some unexpected background tasks during Editing.
3. Does DAE buffer 4 ease the occurrences? (It does for me on 2 rigs: MacPro quad, HD3 and Powermac G5 dual 2.7, HD3).
Note: Using the "Pause Tasks during playback" (in Task Manager menu) is one method of holding off the -9073's, but it no means to I suggest that as a total solution.
Posted on Mar 13, 2008
SOURCE:
Audible click/pop when starting program. ASIO
Due to the DIGI001 ASIO settings, the HALion engine and program should be used as a plug-in (VSTi) in your master DAW, (i.e., Sonar, ProTools, Cubase, etc.) and it should fix the problem. Ensure that your drivers are updated and direct all signal traffic to the input device that is shared throughout your system or simply reassign your "patchwork" through the main DAW as mentioned above.
Peace
DJDIRTYDISHEZ
Oct 12, 2009 | Steinberg HALion 3 Full Version for PC,...
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Mbox
This means that your firmware on the Mbox and the drivers need to be updated. I had the same problem afte updating my protools from version 6.7, Did you recently do any protools upgrades? You can go to Digidesign>My Digi>downloads>Mbox>firmware updates or>driver updates
Oct 17, 2008 | Digidesign Mbox External Sound System
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the A..audio column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Setup
plz give solution how to driver install
May 31, 2008 | Digidesign Mbox External Sound System
Digi mbox
what are you trying to play music through? what out and is i t selected? are you useing protools and trying to get playback?
Mar 18, 2008 | Digidesign Mbox 2 Barebone
Protools m-powered problem
Hi Reidmemusic
There are wide and varied reasons why you are getting this error, it is an indication of a plugin not responidng. Going through and disabling plugins may help you to find which one, and then reinstallation of the offending plugin should fix it. If not, then get back to me here with details of the plugin causing the problem and we shall go further
regards
Graeme
Mar 18, 2008 | Audio Players & Recorders
89 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
