Question about Dell Inspiron 1200 Notebook
Need help how do i enable ports 24000-24100?
  • hotgurlz Mar 14, 2008
    how do i enable ports 24000-24100 in order 2 play scrabulous.. i have a dell inspiron 1200 notebook
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Enabling TCP/IP ports needs to be done from your firewall. Often (these days) two firewalls are in place. One on the internet router/modem and another on your PC. Example McAfee, Norton, ZoneAlarm, etc. Windows XP and Vista also have built-in firewalls (port blockers). If ports are required to be opened, you need to configure it on your internet router/modem and also on your software firewall (as the case might be).
Each internet router/modem and software firewall have specific ways to configure ports so you have to look up the vendors steps or reply with more info and will respond at best effort.
Mike
Posted on Apr 13, 2008
The USB port is not responding .
  • Well check if any of the ports or drivers are disabled
  • Go to Control Panel click on System and Security and select System.usb-port-not-responding-axg5e5uexnub0ytmax4t3nsm-4-0.png
  • Then Select Device Manager
  • In Device Manager choose Universal Serial Bus Controller
  • Select each Port double click it select Drivers Tab and check if the port is enabled/disabled
  • Enable if the text near it says "Enable the selected device"
  • If these don't have any problem then you have to restart your PC and press F2 or F12 to go to Setup page ( when your prompted to press the button or in some cases you may not depends on the PC)
  • Locate the ports option and enable it if it is disabled
Dec 07, 2015 | Computers & Internet
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
I have an Intel D845GVSR motherboard. The 4 back USB ports are enabled but the two front ports aren't. I also have a Creative Combo NS DVD ROM with card readers in it. My Computer guy enabled the card...
This is probably set in the BIOS. You need to reboot the computer and enter the Setup/BIOS to enable the ports. Otherwise they're physically disconnected in the case and you will need and expert to reconnect.
Mar 07, 2011 | Intel D845GVSR Motherboard
How do i enable port forwarding on my router?
Port forwarding is you need to know what address you to port fowarding. It is usually under the administration tab.
Nov 21, 2009 | Hawking HBR49 Router
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Sep 20, 2009 | Arris SURFboard SBG900 Wireless Router...
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
W4682 desktop none of the usb ports are recognizing anything. i had the power supply changed but it didn't come from an emachine it came from a dell. the old power suppy went out on me but before it did...
you will need to boot into bios and in the periphial device or advanced area it should show the usb devices make sure that they are enabled and not enabled and make sure that the plug and play devices are enabled ok i hope that this is helpful best regards mike
Aug 26, 2008 | Intel Motherboard
I need get my static ip working?
For gaming all you need to do is go to http://whatismyip.com your ip# will come up. Give it to your fellow gamers and they can join your game. As far as ports go, you need to find out what ports are used for your specific game. These can be found easily with a search, theres bound to be a forum or two that have this information available. Once you find out what they are, enter them into your port forwarding page. Making sure you apply your settings to 10.0.0.1.
Jan 16, 2008 | Computers & Internet
Gbic
Hi from the command line interface you will need to login and then type enable (enter) configure (enter), interface fast ethernet all (enter), no shutdown port (port #). Here is a link to the CLI manual if you need more help: http://www116.nortel.com/docs/bvdoc/baystack/doc_pdf/217152-A_CLI_Guide_for_Ethernet_Switch_325-425_Release_3.5.pdf Let me know how it goes or if you need more help. Regards
Sep 25, 2007 | NorStar BayStack 425-24T (AL2012E41)...
Dell Inspiron 1200 Notebook Logo
87 people viewed this question
Alun Cox
