Stuck dvd I have a pye dvd recorder which will not releasethe dvd that is stuck in there! It keeps saying blocked when the eject button is pressed.According to the instruction booklet,this means a mechanical fault but there is no advice on how to fix.
  • 47 Answers
There are a couple of things for you to try.
1. Unplug the machine for 60 seconds then plug it back in and immediately press eject repeatedly before it has a chance to load the DVD. Try this several times as it may not work the first time around.
Second suggestion from web:
1. Switch off the unit at the wall plug.
2. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again.
Keep holding the buttons until the disc tray opens."
Post back if you have success.
Posted on Mar 13, 2008
    Scholar:
  • 49 Answers
I don't know the unit your talking about but I DO know that 1.) sometimes the DVD was put in crooked and get's jammed. Push the eject **** and push IN on the DVD door... it might staighten things out.
Don't put a screwdriver in there and try to wedge it out.... you could do a lot of damage.
Last thought - and ONLY if your comfortable doing this - is take the top off (usually two screews on each side, and take a look. You may see something. But DON'T DO THIS if tinkering is foreign to you. You might get a shock.
If this is an old DVD player, junk it or make an attemt, and if the attemt fails junk it. Let me know how you make out.
Why does my pye py 90DG does not accept any dvd(R-WR)?
Try reloading the driver for dvd player burner. If this does not work try downloading the "read program" for the specified dvd drive.
May 03, 2014 | Televison & Video
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Multi dvd recorder+vcr (LG0 KEEPS REJECTING DISC TRAY
The remote control eject button has been applied pressure. Observe the eject button on remote to dislodge any stuck keys.
Feb 03, 2011 | LG Computers & Internet
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
DVD IS STUCK IN PLAYER , SCREEN SAYS "PLEASE WAIT" EJECT BUTTON DOES NOT WORK , HOW DO I EJECT DVD ?
first turn it off then on again see if that helps. unplug it if you have to
Aug 01, 2009 | LG RH1777 DVD Recorder
Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
May 31, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Cannot record from vcr to dvd
What discs are you using, maybe theres not enough space.
maybe they are dvd-r or dvd+r. The funai units are rebadged pye units so you could try their customer support
Mar 25, 2008 | Funai PY90VG DVD Player/VCR
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
