Question about IBM Infoprint 6500 Matrix Printer
304 barcode damaged
The printer won't print.. getting 304 barcode damaged
  • 1 more comment
  • galvant Apr 17, 2008
    works with ribbon P/N 39U2551 does not work with ribbon P/N 41U1680
  • sai_44 Jul 03, 2008
    I tried using the solution no 2 by printing the congration page and I get Bar Code Error 303 in spite of revesing the spools. Is there a way out to get out of this. Any help would be appreciated
  • toytago Mar 03, 2009
    i was printing and paper caught and stopped. happened twice then i got the message "304 barcode damaged reverse ribbon spools" what do you reverse ribbon spools?
Try one of the following:
1. Turn the printer off, then back on
2. Reverse the ribbon; perhaps it is upside down
Once the printer is powered on and the ribbon is in correctly, the printer should work.
Posted on Mar 27, 2009
Change ribbons.
Posted on Sep 22, 2009
Had same error. We can print a configuration page. Other part of the 304 error is Reverse Ribbon Spools. Flip the ribbons over. We did this and we were back online with Ribbon at 100%.
Posted on Mar 27, 2008
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
My printer won't print barcodes
How can you check for RIBBON WRINKLE and fix it without buying a new part. My printer is new.
Jun 27, 2012 | Canon Office Equipment & Supplies
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Intelligent mail barcode
I'm 75% sure it will, without looking at the postal intelligent mail barcode printing specifications... I will be glad to answer your question, if you can get me the Specs. for the new postal intelligent mail barcode... the other important question is... what is you current IBM 6400-XXX printer configuration? press the print config, then the Start on your printer. 1st Paragraph is all you will need to give me... Worst case, you might need a differenent Emulation program...
Jan 30, 2009 | IBM 6400 Matrix Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Feb 27, 2008 | Zebra Eltron LP 2824 Thermal Printer
Check Prinhead problem
This error occurs when the head has some damage. Check also that the head of the cable is properly connected.
Feb 18, 2008 | Paxar Monarch 9403 Thermal Printer
IBM Infoprint 6500 Matrix Printer Logo
1,355 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
