Question about NEC AccuSync LCD223WXM Monitor
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes . In the box with the volume showing it say's there is a reset button and next to it it say's mute but I don't know how to fix it. If I push the reset button on the monitor the speaker ion has an X next to it and the volume color turns blue. No sound either way. Please HELP!
  • 55 Answers
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Posted on Mar 15, 2008
I can not get any sound out of the speakers. There is 6 ports (all different colors) I have tried everything. I have had the speakers for a year now. I cleaned the computer and the speakers came unplugged...
first connect both the satallite speakers to line out which is located near to the power switch (speaker out)
Now vertically above these 2 connectors there will be another connector that says remote control (audio input) this is connector that gets connected to your PC.On your PC this should get connected to the green port named as line in.
connect the power cable to mains
switch on th power switch which is situated at the rear of the subwoofer.The power indicator light will be lit up with a blue light
Now adjust the speaker volumes and try to play music
Dec 26, 2010 | Philips SPA2300 2 Speakers
Cannot make speakers work
You need to use audio cable with ministereo phone plug at both ends of the cable, then one end is plugged into the monitor audio line in jack (usually Green color), another end of the cable will be plugged into the audio line out (Green color) of the PC. Set the volume level to about 1/2 way at first and then adjust the volume control panel (Master volume and WAVE level, these two controls affect the sound output feeding the monitor) on the PC.
You can try feeding the monitor with MP3 player first to make sure the monitor speakers are working properly first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Acer B223W 22 inch LCD Monitor
No volume this monitor was given to me the volume is all the way up on desktop and I cant see where any speakers can be put.
Are you sure the monitor can handle speakers? Maybe it has it's own speakers, maybe it has no speakers at all. You can always plug the speakers into your CPU into the sound card, it is usually the green audio port.
That said, some things that you can trouble shoot.
  1. Make sure that the volume is all the way up on the desktop.
  2. Make sure that the volume control is all the way up in the control panel sound option
  3. Make sure that nothing has been muted, the control panel allows you to selectively mute a single device.
Apr 15, 2010 | Samsung 226BW Monitor
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
I recently bought a Windows 7 64 bit PC. I have Optiquest monitor with built-in speakers. The sound was working fine and then it stoppped. I tried stand-alone speakers, then anoither monitor with speakers-...
Go into control panel / sounds / sounds and audio / select audio blind / should see a driver listed in each device. Back to sounds blind /test sound, if you can see the black arrow but its greyed out then driver is faulty. If you can click on it and it changes baxk to th esquare all is OK, ensure the sound jack is plugged into the GREEN ones at rear PC. Also check in volume blind that speakers are selected.
Feb 24, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Dec 12, 2008 | Acer V223WBD Monitor
RIGHT SPEAKER
When did you purchase your monitor? if it sitll have warranty then call the manufacturer to replace it. You have encountered minor defects. However u can have sound for your computer. Use a desktop speakers connect it to the back panel of your tower case/casing. there u can locate the jack for speakers, jack's color is green. regarding to the CD's you burned, Speakers cant affect the quality of sound burned in your cd.
Dec 26, 2007 | Compaq FP 7317 17" LCD Monitor
NEC AccuSync LCD223WXM Monitor Logo
290 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
