Question about BenQ FP791 17" LCD Monitor
Bebq monitor Q7T4 17 INCH
WHEN I START UP THE HOME PAGE COMES UP AND THEN IT GOES OF AND I HAVE A BLACK SCREEN . I TURN THE MONITOR OFF AND ON UNTIL EVENTUALLY THE HOME PAGE STAYS ON , IT TAKES ABOUT 7 TO 10 TIMES SWITCHING THE MONITOR OFF AND ON UNTIL THE PAGE STAYS ON AND THEN IT IS GOOD FOR THE WHOLE DAY. UNTIL IT IS SWITCHED AT NIGHT AND THE SAME THING HAPPENS THE NEXT DAY. HOPING YOU CAN HELP THANKYOU.
    Novelist:
  • 138 Answers
If you can check your monitor with another computer, that would be the best inspection and make sure that the problem is from LCD monitors. The following steps are how to check what wrong with your monitor.
1. Power on both CPU and monitor. After it goes off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely.
2.If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace.
3.If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Posted on Mar 14, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Monitor screen goes white at start up
That could be the monitor or the video/graphics card in the computer. Try another monitor as a test to narrow the problem. If it's a laptop, therer's usually a VGA port where another monitor can be installed. You might need to press a Fn key combination to turn on the second monitor in that case.
Feb 04, 2018 | IBM ThinkVision L201P (Black) 20.1 inch...
When computer is turned on screen comes on for 2 secs turns black screen , but can VAGLEY see what is on screen. Turn screen off then back on, same thing happens, do above again, then screen is fine from...
The backlight is not on, it can be due to bad caps, lamp assemblies, failed components, etc. Please read my guide and look at the failed caps and monitors.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | Acer AL1916W 19" LCD Monitor
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
MY screen will stay on for 30 seconds, then goes black.
you Screen has a Soildation problem take it to near by electrition he will resolidate your screen and it will then work fine..
Aug 27, 2009 | Proview PL 566s 15" Flat Panel LCD Monitor
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
BenQ FP791 17" LCD Monitor Logo
270 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
