Question about Microwave Ovens
I have an Ikea MBI 710 S Microwave. For the first year it was quiet, but it is now very noisy. When the microwave function is used there is a loud buzzing. The whirlpool engineer has diagnosed this problem as the magnatomitor causing the thin metal sheet of the case to reverberate. The engineer said he may be able to provide a special material that may stop this from happening without compromising safety or functionality of the unit.
  • ahemmings Jun 10, 2008
    Tried this. I have since taken it to a specialist repair centre and they want 140 pounds to replace the transformer. They are confident that this is the cause of the problem... its nice to have a second opinion before spending this sort of money...any comments? AH
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Try tightening the screws up on the magnetron and transformer as this often causes the problem. If they are tight, loosening them off and re-seating them can also work.
Posted on Mar 18, 2008
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    The oven has trouble ligting,and make,s a boom sound when lighting
    Magnetron
    If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Enter your model number to see parts for your microwave.
    Help me find my model number
    Exhaust Fan Motor
    If the microwave is loud when running the fan motor might be
    Stirrer Motor
    If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor
    If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Apr 02, 2013 | Microwave Ovens
    Coleman EB15A - Buzzing noise from transformer area, no heat or fan
    see this causes and proceed. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 18, 2012 | Microwave Ovens
    Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
    see this causes and fix it. God bless you
    Oct 15, 2012 | Microwave Ovens
    GE Microwave (JVM1860CD001) control board buzzes.
    Oct 10, 2012 | GE Microwave Ovens
    Microwave oven has become very noisy
    Oh, this is a UK/European model...
    I have no info on that, so your best bet is to contact Panasonic UK:
    http://www.panasonic.co.uk/customer-Support/index.asp
    Good luck.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Feb 25, 2008 | Microwave Ovens
    Noisy Exhaust Fan
    check exhast fan fittings and clean the bush..
    Nov 29, 2007 | Frigidaire PLMV169DC Microwave Oven
    Noisy turntable
    I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
    Mar 25, 2007 | De Dietrich DME112X Microwave Oven
    Microwave Ovens Logo
    165 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
