Question about Lands Phones
Astra config file to router
How do i upload the config file to the router? everytime it loses power I have to go in and fix it.
  • 807 Answers
Which router is it, make and model.
Posted on Mar 14, 2008
SOURCE:
Cisco Unified Communications 500 Series reset password with out losing my configuration
if you are talking about your enable password you will have 2 choices which are a factory reset or evoke ROMMON. The simplest way is to backup your running config via TFTP or do a #show run and copy and paste the whole config to a txt file and then reset to factory default and then just load(or paste) that config and then do a #copy run start.
Nov 17, 2011 | Cisco Unified Communications 500 Series...
Tip
Why lose a router settings after a power outage?
Question:<br> After a power outage <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"><b>Cisco 1900</b></a> lost my router configuration, was saved, reload the configuration, save, reboot and no problem.<br> How to know if my router is properly, all my services run smoothly? Why it happens that configuration is lost?<br> Are there any benefits the settings saved in flash?<br> Answer:<br> Did you check if the NVRAM was empty or running config was empty?<br> If router booted with empty running config, it could be that startup got erased (NVRAM issue) or that it did not load it from startup to running (likely config-reg) issue.<br> Since in your case config-register ix 0x2102 and was not changed, the problem should be with NVRAM.<br> From me exprience, I have seen that in the following cases:<br> - config was not saved to NVRAM;<br> - at the time of powerdown the NVRAM startup file was accessed for editing (e.g. saving running config) and got corrupted or erased;<br> - NVRAM HW issues cause file system problems.<br> Is it reproducible in your case? E.g. if you powercycle the switch, do you see the same problem with config loss? If yes, check the NVRAM content. <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"> <b>Cisco 1900 router</b></a> That could give some hints.
on Aug 22, 2013 | Cisco Computers & Internet
Cisco 2514 does not switch on straight away. It powers on about 1min after switch depressed. it also loses the correct date and time if switched off.
if you issue the command show version
At the bottom written in bold you should the config register settings these nee to be as shown at the bottom of this page
R1#show version
Cisco Internetwork Operating System Software
IOS (tm) 2500 Software (C2500-JS-L), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 06-Jul-00 10:02 by cmong
Image text-base: 0x0306F914, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFT
WARE (fc1)
R1 uptime is 1 day, 5 hours, 39 minutes
System returned to ROM by power-on
System image file is "flash:c2500-js-l.121-3"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 11844920, with hardware revision 00000001
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2102
if yours differs the use the these commands to correct it
R1>en
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#config 0x2102
R1(config)#^Z
R1#
Hope this helps
Mar 15, 2011 | Cisco 2514 Refurbished Router (CSCO2514)
Everytime I lose power it becomes unsecure?
You need to update the firmware of the router. You may avoid this from happening again by connecting the router to a power surge protector instead of plugging it directly to the wall.
Jun 06, 2010 | Linksys Wireless-G WRT54G Router
Linksys Routers lose setup
I Had to replace a Linksys for a client because every time was a power outages the router was losing the setup. So try unpluging the power supply.
Jan 06, 2010 | Linksys Wireless-G Broadband Router
Can't open and operate scanner UMAX Astra 2000P
I just finished uploading the driver software here:
http://www.filefactory.com/file/ag7c9c2/n/UMAX_ASTRA_2000P_vs355p_exe
Click on FREE DOWNLOAD and wait for he 30 second countdown then click on the big blue Download link that will appear. The
file should start downloading. I'm assuming you need it for Windows 2k or XP. It wont work in Vista.
Mar 12, 2009 | Umax Astra 2000P Scanner Flatbed Scanner
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
Software
http://www.dynexproducts.com/t-customer_support.aspx
Enter DX-E401 into Search and Click GO
Click this link under Product Matches
Dynex 4 Port Ethernet Broadband Router
You now have links to manuals, firmware and FAQs.
There is firmware that can be uploaded to the router and the FAQ and Manuals will explain the configuration process
Dec 16, 2007 | Dynex DX-E401 Router
Lands Phones Logo
217 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
