Question about Canon PIXMA iP4200 InkJet Photo Printer
Printer offline Hello... I have my printer connected to my laptop and it is on, but when I try to print something it says printer is offline... I also tried to add a new printer and PnP couldnt recognize it... What might be the reason? the cable ? I was using it the day before yesterday without any problem, but cant use it now :-(
  • Anonymous Jul 31, 2008
    i am trying to print and the printer is on but when i click to print it diesnt want to print :S
    an error comes up with a small printer icon and a question amrk and all my print attempts r there
    Problem Solver:
  • 15 Answers
Go to the settings, you can see the printer and faxes, click to it and if see the printer driver is offline then right click on the printer driver in the pop menu you can see the use printer online click on it, if again it shows the printer offfline please change the usb cable and try again, if again the problem occurs reinstall the printer driver and also check the usb port has been choosen
Posted on Apr 29, 2008
ML1865W offline
Try disconnecting the printer completely from power.
Reboot your system and re-connect the printer again.
Check for paper jams and clear them.
Delete any print queues.
Hope it helps.Thanks!
Jan 05, 2012 | Samsung ML1865W Laser Printer
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
Printer is offline
try to ping if printer ip reachable. if yes try to connect again manually from add remove printers.
Apr 15, 2010 | HP Photosmart C7280 Laser Printer
HOW TO GET MY PRINTER FROM OFFLINE AND TO PRINT. we HAVE A HOME COMPUTER WHICH THE PRINTER IS SETUP TO BUT WE ALSO HAVE IT WIRELESS FOR OUR LAPTOPS. NOW ITS NOT PRINTING FROM HOME COMPUTER ITS SAYING ITS...
Make sure that the usb cable is well connected from the computer to the printer .... try switching usb ports on the pc....
if it still stay offline... you will have to delete it and make a new installation of the printer driver....
But i'm pretty much sure that the usb cable is losse or something
Jan 24, 2010 | HP J4680 Office Jet All-In-One Printer
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Printer lists work offline
brenna130,
Try not to interrupt the infrared port so that the connection of both laptop and printer will not be offline
Jul 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
291 people viewed this question
old marine
old marine
