Question about Scytek 2000RS Remote Control
Galaxy 2100RS Just installed a Galaxy 2100RS in a 2004 Suburban. It starts the vehicle OK. After starting there is a brake indicator light illuminated and there is a SERVICE 4WD indicated. Stepping on the brake will clear the idiot lights but the SERVICE 4WD is still present. To clear this alarm it is necessary to turn off the engine and restart. Has not worked correctly since installation. Any suggestions?? Thanks for your help. Roger Curtis
    Problem Solver:
  • 13 Answers
If this vehicle has a white wire in the ignition harness it needs powered by the ignition out of the remote start if your remote start doesnt have a second ignition use relay not poering this wire will ruin your transmission the white wire must have power this should solve your problem dont use remote start until you fix this problem or it will cost alot of money.
Posted on Mar 15, 2008
  • birdieman Mar 15, 2008
    go to bulldog security.com and look up your vehicle it tells you this i have that remote start and it works great
Cruise control does not activate when turned on,brakelights work pedal is not stuck on.when starting vehicle instrument cluster illuminates speed control lamp
Brake lights are not an indication that the cruise control works. The brake light switch and the cruise control switch are usually 2 different switches. Physically inspect the brake pedal shaft.
Sep 23, 2015 | Cars & Trucks
2004 pt cruiser brake warning and ABS light on, no ABS installed
CLOCK SPRING!! IF ALSO NO HORN, THAT IS INDICATOR
Nov 09, 2012 | 2001 Chrysler Voyager
2004 ford freestar flashing exclamation mark with circle
The exclamation light is an indicator that the transmission has a problem. Take it to a transmission place,for them to diagnose before it's too late.
Oct 18, 2010 | 2004 Ford Freestar
How do u change speed sensor cable on a 2005 chevy suburban
Speed Sensors (2 types) Removal & Installation Front To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the wheel assembly.
  3. Remove the brake rotor.
  4. Remove the Wheel Speed Sensor (WSS) cable clip from the knuckle. chevy_aval15_02-04_speedsensorharness.gif
  5. Remove the WSS cable clip from the upper control arm.
  6. Remove the WSS cable clip from the frame.
  7. Remove the WSS cable electrical connector.
  8. Remove the WSS mounting bolt. CAUTION
    Carefully remove the sensor by pulling it straight out of the bore. DO NOT use a screwdriver, or other device to pry the sensor out of the bore. Prying will cause the sensor body to break off in the bore.
  9. Remove the WSS from the hub/bearing assembly.
To Install:
  1. Seal the WSS bore to prevent dirt or debris from falling into the hub.
  2. Clean the mounting surface on the hub to remove any rust or corrosion.
  3. Apply wheel bearing lubricant, GM P/N 01051344 or equivalent to the hub surface and the sensor O-ring to ease sensor installation.
  4. Install the WSS into the hub/bearing assembly.
  5. WSS sensor must be seated flat against the hub.
  6. Install the WSS mounting bolt. Tighten to 13 ft lbs (18 Nm).
  7. Install the WSS cable mounting clips.
  8. Connect the WSS cable electrical connector.
  9. Install the brake rotor.
  10. Install the wheel assembly.
  11. Verify proper operation.
Rear To Remove:
  2. Disconnect the electrical connector. chevy_aval15_02-04_speedsensorrear.gif
  3. Remove the wheel speed sensor bolt.
  4. Remove the wheel speed sensor.
To Install:
  1. Install the wheel speed sensor using a twisting motion, until fully seated
  2. Install the wheel speed sensor retaining bolt. Tighten to 10 ft lbs (13 Nm).
  3. Connect the electrical connector.
  4. Lower the vehicle.
  5. Perform a low speed test for proper operation:
    • Start the engine and allow it to idle.
    • Verify the ABS indicator or the traction assist indicator remains illuminated.
    • If the ABS indicator or the traction assist indicator remains illuminated, DO NOT proceed to drive the vehicle until it is diagnosed and repaired. Check the wheel speed sensor electrical connector to ensure it is not damaged and is installed properly. If the lamp remains illuminated, diagnostics are required.
    • Select a smooth, dry, clean, and level road or large lot that is as free of traffic and obstacles as possible.
    • Drive the vehicle and maintain a speed of at least 16 km/h (10 mph) for at least 5 seconds.
    • Stop the vehicle and check to see if the ABS indicator or the traction assist indicator is illuminated.
    • If an indicator is illuminated, diagnostics are required.
---------------------------------------------------------------------------- Vehicle Speed Sensor Operation Vehicle Speed (VSS) Sensor(s) input is used by the EMS to determine vehicle speed. The VSS generates a signal that increases in frequency proportionate to vehicle speed. The EMS has a base frequency stored in memory for a distance of one mile. By comparing the input and stored value the EMS calculates vehicle speed.
VSS types include: photo-optic, permanent magnet generators or Hall Effect technology. The EMS may use other sensors on the vehicle such as ABS wheel speed to validate VSS operation.
VSS information is used to calculate vehicle loads including: torque converter application, cruise control, fuel cutoff/speed governance strategies, instrument panel speedometer and more.
Modified drivetrain components such as final gear sets and/or tires can alter VSS input values to the EMS. Improper signals can alter torque converter clutch (TCC) application, shift points, cruise control operation as well as many other systems relying on vehicle speed input.
Related Symptoms A faulty speed sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit can cause the following symptoms.
  • Overheated transmission
  • Increased emissions
  • Poor fuel economy
  • Stalling on deceleration
  • Improper shift points
  • Cruise control inoperative
Sep 02, 2010 | 2005 Chevrolet Suburban
2004 Saturn Ion - Parking brake will not go off. Precision Tune says "brake float switch broken - held in by piece of silicon. Pedal hard and functioning normal. Electrical problem relates to brake...
It's called Brake Fluid Level Switch Try a auto salvage yard > Couple of buck's
Brake System Indicator
The instrument panel cluster (IPC) illuminates the brake indicator when the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination. If the vehicle is shifted out of park with the park brake engaged, the BCM activates an audible warning.
• The body control module (BCM) detects a low brake fluid condition (signal circuit is low). The IPC receives a class 2 message from the BCM requesting illumination.
• The IPC detects a low brake fluid condition (signal circuit is low).
• The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
Jul 08, 2017 | 2004 Saturn ION
Parking brake light stays on.
Do you have a separate parking brake light and a "regular" brake light? Most vehicles only have one light, it illuminates when the parking brake is set, but it also illuminates when the system detects a failure anywhere in the brake system.
You could have a separate light for the anti-lock brake system (ABS ).
Your description of a light that is on till you apply the brakes is usually a sign of some sort of system brake failure. Start with brake fluid level, then inspect the brakes at each wheel, looking for a leak.
If nothing detected there, then you likely have something more serious. (Master brake cyclinder bad, possible something in the ABS brakes, etc.)
Others may disagree, but I would suggest not driving the vehicle (except to a mechanic) until this is corrected.
Oct 01, 2009 | 2004 Nissan Frontier
Light
From left to right
1. The wrench light is the service interval light.It will illuminate after about 4800 miles or 358 days to remind you your vehicle is due for service.To reset hold the SELECT and UNITS buttons on the trip computer for 5 secs. The light will illuminate then extinguish itself after about 4 secs.
2. Frost warning light. This light illuminates yellow when exterior temps are between 39 to 32 deg. F to warn you of possible icing on the roads.It will illuminate red if temps drop below 32 Deg.
3. Brake pad warning. Will illuminate when brake pads have worn down to the sensors in the pads.
4. Washer fluid warning.
5. Door Ad-jar
6. Bulb failure. Indicates an exterior bulb is out.This will illuminate until brake pedal is pressed after starting engine unless of course one of the brake lamp bulbs is burnt out.
Feb 26, 2009 | 1999 Mercury Cougar
2004 A4 1.8T Brake Lights Remain On After Car Is Parked
Sounds like your brake light switch is on its way out. Its a simple fix and a cheap part. It will need to be done immediately as not only can the lights staying on drain your battery but it can also cause lack of power and not put the brake lights on when braking. The switch is operated by the pedal itself and requires the drivers underdash trim to be removed. With this off the switch can be accessed and replaced. If you can get a vehicle technician to fit it, do so, as they are quite fragile and new switches can become useless if fitted incorrectly. Good luck
Feb 07, 2009 | 2004 Audi A4
I have a 2003 GMC Savana Van. The brake light came on and the brake alarm rings continously but will stop if I hit a bump (and then start again if I hit another one). I'm thinking a loose wire but several...
If someone took the time to look at the electrical schematic you will see several grounds in the circuit My first place I would go would be to check all the Grounds and Connections for the Brake Fluid level control, Brake Warning Indicator
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
  • The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The electronic brake control module (EBCM) detects a closed brake pressure differential switch. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP) . The IPC receives a class 2 message from the EBCM requesting illumination.
  • The IPC detects a closed power brake booster alarm switch and closed power brake booster fluid flow alarm switch. The IPC illuminates the brake warning indicator and sends a class 2 message to the radio requesting the brake warning alarm.
  • The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
  • The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
Driver Information Indicators and Messages
The following indicators are used to inform the driver of several different factors.
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when the following occurs.
  • The Body Control Module (BCM) detects that the park brake is engaged. The IPC receives a serial data message from the BCM requesting illumination. The brake warning indicator flashes at a rate of approximately twice per second when the park brake is engaged.
  • The EBCM detects a low brake fluid condition or base brake pressure differential and sends a serial data message to the IPC requesting illumination.
  • The IPC performs the bulb check.
  • The EBCM detects an ABS-disabling malfunction which also disables Dynamic Rear Proportioning (DRP) and sends a serial data message to the IPC requesting illumination.
Here is a description of how the system works But i would check my Grounds and connections
www.aceautomotive1.com
Contact me if you need any more information Ill be glad to help
Aug 01, 2008 | GMC Savana Cars & Trucks
Scytek 2000RS Remote Control Logo
166 people viewed this question
Top Scytek Televison & Video Experts
Marvin
Marvin
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
