Question about Frigidaire FGF366E Gas Kitchen Range
No Power to FGF366ESB Range
I have no display and the oven does not work on my Frigidaire range. We have checked the circuit breakers, don't really know where else to look!
  • johnkimcorne Jan 08, 2009
    I have the same problem, the oven control resets when I unplug it
    but this happens a lot about every other day is there a voltage filter I can put in between the high and low voltage or will replacing the control work
    President:
  • Frigidaire Master
  • 2,651 Answers
Althougy ou cked circuit breaker did you try unplugging unit waiting 2 min then plugging back in. sometimes you get lucky and will reset. has to do with high voltage bleeding through to low voltage wiring. if it works, your good!!!! if not remove the back panel and check the clock/control for icoming power. as long as you have 110v going in at the black (L1) you should have a display. if you have powerand no display you need a new control.
Posted on Mar 14, 2008
My frigidaire range/oven model FEF365BWC is not working the surface and the oven are both not heating up. Everything other than that are working the oven light and the clock are working fine
You are not getting 240 volts to the heating elements. Go outside to the circuit breaker panel and find the circuit breaker for the range. It will be two breakers with their reset handles linked together so if one breaker trips so will the other. That's the part that isn't working correctly. Only one is tripped allowing the controls and lights to operate . Try manually resetting it. It most likely won't work, so you'll have to replace the circuit breaker.
Jan 22, 2016 | Frigidaire Kitchen Ranges
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Power off for a day, now I don't have a clock display, can't get it back on. Oven works ok
I appreciate your inquiry, friend!
Based off what you have described you powered down your Frigidaire range and now the display will not work. It sounds like there could be a possible miscommunication within your range. To help clear out any false errors or miscommunications I would recommend performing a reset on your range and you can do that by flipping off the household circuit breaker for at least ten minutes. Hope this information is helpful. -OOS
Mar 29, 2015 | Frigidaire Kitchen Ranges
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
We self cleaned our Bosch oven yesterday. Now the
I would check the following because during a self cleaning cycle a oven gets very hot and draws alot of power and this could of happened
Fuse/circuit breaker
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oven does not start. checked owner's manual. Still does not start. The control panel works and does not display a problem code. The broiler and top burners work. Ideas?
Hi
You must check the main power wires where they enter the range at the T-block, sometimes they can burn off. Also check house fuses (or breaker) that supplies power to the range. Checking with a volt meter, you should get 240 volts between the black and red main power wires. The range receptacle and power cord can also burn and fail. Also check the fuse/circuit breaker and check to see if power is getting to the range/oven. If anything does not turn on then check for a blown fuse or tripped circuit breaker. Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to. There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | Magic Chef Ovens
I have a freestanding Frigidaire electric range that has been working fine but a little while ago I'll is using the oven and the top buners at the same time and suddenly lost complete power to everything...
Recheck you breaker. Turn it off and then turn it back on a couple of times. There aren't any fuses in the stoves. If that doesn't work you'll want to call an electrician to check your plug and breaker. Good luck.Please rate me so I know how I'm doing. Thanks
Dec 30, 2008 | Frigidaire FEF336BC Electric Kitchen Range
HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Oct 21, 2008 | KitchenAid KESC307 Electric Kitchen Range
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FGF366E Gas Kitchen Range Logo
145 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
