Question about Logitech X-230 Computer Speakers
Computer speakers hey my left computer speaker is making a really bad "buzzing" sound when i double click on something. it just started doing this as soon as i updated to windows vista. it also buzzes really bad when i'm in the media center of windows vista as well. help?
  • snaremore Mar 13, 2008
    hey thanx for the advice, i went to update the driver and it said that the i already had the latest software for the sound card. any other suggestions?
  • 298 Answers
Try updating your drivers for your sound card.
Posted on Mar 13, 2008
SOURCE:
My monsoon computer speaker system bass has a constant buzzing sound as soon as you turn it on. The 2 speakers are fine but the bass is consyantly buzzing/humming
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 04, 2011 | Computers & Internet
Need help to hookup speaker and sound for compaq presario desktop computer. I can not get any sound, and can not hookup my speaker.
Hey,
well first up you need to connect computer speakers to the GREEN sound socket at the BACK of the computer.
power up the speakers!.
power up computer!
go to start menu click on "Control Panel"
Look for an icon called "sound" or "audio devices" double click on icon.
in the Sound Properties window check that there is a sound card driver operating.. if there is no logo displayed here then you haven't installed correct drivers for the soundcard if there is no driver installed then you need to contact a local computer repairer to have a look for you and install the correct drivers for your soundcard!
if there is a logo there then check that the volume in turned up on the computer. do this by RIGHT clicking on the drivers logo and select PROPERTIES.
i hope this helped!,ben
Jan 13, 2011 | Computers & Internet
Center speaker does not have sound
First double check all connections. And if that does not fix pull the cables on one of the working speakers and plug into the center speaker to make sure it is not a bad speaker. If the speaker works connect them back the way they were and Click Start then open Control Panel look for Sounds and Audio Devices click on it. It should open to Volume now down on the bottom you will see Speaker settings click on Advanced. Speaker Advanced Audio Properties should open look for Speaker setup click on the little blue V, go down and click on Surround sound speakers now click Apply then OK and OK again. It should work correctly now.
Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
Oct 14, 2010 | Logitech X-530 Computer Speakers
My speakers won't make a sound.
Process of elimination... check your cable hookup first. then control panel and check sound, right click on properties tab and do a diagnostic.
Jun 02, 2010 | Creative Labs Inspire T3000 Computer...
One speake is not working
The sound MAY BE turned down to zero using the Windows sound program/Mixer . Go to START - CONTROL PANEL - HARDWARE AND SOUND - MANAGE AUDIO DEVICES - and double click on the speaker icon then check the BALANCE control it should be set a 100% for both left and right. Click CONFIGURE and TEST the speakers.
If that doesn't work you have either a bad plug (on the speakers or on the laptop) or one bad speaker or the plug is not fully inserted or the speakers a just incompatible with the laptop. You might test the speakers on another computer.
Jan 28, 2010 | Audio Players & Recorders
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
COMPUTER PROBLEM
Make sure your mute is not on, your volume is turned up, your speakers are plugged into the correct port, and the sound drivers are installed for your sound device.
  • Turning the mute on and off and volume up
  1. Down by the clock there is something that looks like a little grey speaker. If you left-click does, is the Mute check box, checked?
  2. Make sure the volume bar is up. You should hear a "beep" sound when you click and move the slider up and down. This signifies the volume.
  • Speaker Port
  1. Check that the speakers of your PC are plugged into the correct port. On most motherboards and sound cards, the correct port for the front left and right speakers are usually color coded as a "light green".
  2. Ensure the speakers are plugged into this port.
  • Make sure the drivers for your sound device are installed
  1. Go to Start -> Control Panel
  2. Double-click on "System" (without quotes)
  3. Select the "Hardware" tab (without quotes)
  4. Click the "Device Manager" button (without quotes)
  5. If you see something that mentions sound device and it has a yellow question mark or yellow exclamation mark next to it, the drivers are not installed correctly or there are errors with the device.
  • If the above steps do not work
  1. If the above steps do not work, consider having your PC professional checked out as there are several other things that MAY be wrong with the PC and diagnosing these issues via the internet would be near impossible.
I hope this helps you resolve your problem.
Mar 06, 2009 | E-Machines eMachines Desktop PC
Durabrand 2.0 CH USB Speaker System
Try this, go to control panel and double click Sounds and Audio Devices. Then click advanced, under speaker settings and make sure your settings are desktop speakers. Also, in control panel, click Sound Effect Manager and do a speaker test. This should help.
Jan 20, 2009 | Audio Players & Recorders
Speakers produce effect noise but no music...
Check to make sure you have not lowered volume or muted any sounds--- go to speaker icon in tray, double click and check to make sure all sounds are on! Hope this helps.
Feb 13, 2007 | Dell A215 Computer Speakers
Logitech X-230 Computer Speakers Logo
98 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
