Question about LG L1752T-BF 17" Flat Panel LCD Monitor
LG L1752TX-BF... HDCP or not???
  • 1 more comment
  • lafy22 Mar 13, 2008
    so i have to plug my PS3 on my video card and it will work?
    I do and i have a beautiful black screen!
  • matty boi May 14, 2008
    i have a 42 inch screen and ps3 with a hdmi cable all i get is black screen
  • 73 Answers
It is but is your video card hdcp ? thats what u nee dto worry about not the screen unless u want full 1080 p resl then u want 22 in or beter with native of 1660 x hi end res but no ever screen is just wather or not ytour video card is only super hi end video cars are ok thx nick
Posted on Mar 13, 2008
  • 3 more comments
  • djnick989payments jones
    more less is your video card hdcp ready ok dont worry about screen
    if its onboard video it sure isnat need least nvidia 7800 or better or ati 1900gt better to get true hdcp complaint ready for hi end gaming ok hd content
    oh u wnan stick your ps3 in screemn ? not made for it u need hdtv ok with hdmi in not pc screen not made for ps3 noway look terible also wont give u hd visoion like u want ok need hd tv lcd sharp or samsung best for gamers best price too plamsa erther one 700 bucks dont want cheap on e not on ps3 thats hi end
    cant use screen u wann with your ps3 unless u could trick it see what happends buy buying hdmi cable for ps3 then hdmi adpoter to dvi ok directto screen to test if that dont do it then screen not made for res of ps3 ok
    that assuming this lcd screen 17 in is dvi input ready
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
Anyway of upgrading TV to support HDCP? Will not support HDMI w/o it/
look on ebay for an adapter try "HDCP to HDMI adapter" as a string i wont look but i can bet your not the only one
and some guys are good to solve simple wires and balance issues
Nov 30, 2014 | LG Televison & Video
Need electrical diagram for LG flatron l206wtq-bf
hello Buddy Mcsparrin for 5 parts capacitors how much ohm did you add with screwdriver to discharging capacitors ?
Oct 06, 2012 | LG FLATRON L206WTQ-BF Monitor
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
Hi i have a lg l226wty-bf monitor that does not turn on and has a blue led flashing on and off under the power button. What do i do?
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Apr 07, 2011 | LG L226WTY-BF Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
How to turn off HDCP on 42PC5D
HDCP is detected and therefore automatic. You can pass video and audio via HDMI without HDCP protection IF the video and audio are not protected. If the content is protected, you will not be able to view or hear it without HDCP. So the best answer would be... by passing unprotected content to the TV. You can't just shut it off, it's part of the copy protection scheme. I hope this was helpful.
Apr 16, 2010 | LG 42PC5D Television
My model no is FLATRON L1752S-BF and serial no is
The LG Flatron L1752S is made in 2006. You can go to LG website here. I do not believe it is under warranty. http://www.lg.com/us/support/repair/support-warranty-claims.jsp
Apr 05, 2010 | Gateway FPD2275W LCD Monitor
When I open game the monitor become black and show: Analogique shortcut 53.6 Khz/85 hz
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | LG Flatron L1752TX 17" LCD Monitor
My LG L196wtq-BF went black this morning. No light on the power switch. How do I get the back off the monitor?
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
Aug 31, 2009 | LG L196WTQ-BF 19" Monitor
LG L1752T-BF 17" Flat Panel LCD Monitor Logo
228 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
