FixYa.com
Tags:
Jensen CD400M CD Player
I think it got wet
posted by b0mbtrack on Mar 13, 2008
put the stereo in a dash on a boat, tested it out and worked fine. Was fine for a few days then it rained, i guess it isn't a waterproof area that i put the stereo in. I went to try it out today and the numbers on the screen were all screwy looking, couldn't actually read anything on the screen. tried to put in a cd but it wouldn't take it, and it just seemed to be doing random things like trying to eject out of nowhere. When i put the cd in and it came back out (only went in about half way) it came back out with water spots on it. after that i realized it must have gotten wet in there. Is this unit fixable or do i have to get another?
Comment by b0mbtrack, posted on Mar 13, 2008
thanks, i was afraid of that but i might as well give it a shot.
Comment by b0mbtrack, posted on Mar 14, 2008
i can't seem to find this unit anywhere at all, is there another jensen one i can get that i could just slip the unit out and slip this one in without changing the wires or the housing?
Thanks, i do have my manual but i'll also try to give them a call just to be sure.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
zzedly
Rank:Guru Guru
Rating: 87%, 136 votes
Yike! As with most electronics, they are necessarily dead when they get wet, but you do have to be very careful with them until they're dry. Here's the best you can do:
  1. Remove the stereo from the boat completely.
  2. Remove the cover(s) from the stereo to expose as much of the inside to air as possible.
  3. Let it sit for a few days inside to dry.
  4. Reassembly it and install it back in the boat.
If you're lucky, the unit will return to normal operation. Unfortunately, my guess is, since you powered the unit up when it was wet, damage may have already been done.
Comment by zzedly, posted on Mar 14, 2008
You're right, the CD400M looks to be well discontinued. I can't even find an owner's manual online, so your best bet is to compare your owner's manual (you still have it, right?) to this one for the Jensen MSR3007 and see if the wiring and connector seem to match up. Either that, or contact Jensen directly.
Rating Locked! (?) b0mbtrack has rated this solution as FixYa!
Can you Help with these In Dash Receivers problems?
Jensen CD400M
Radio is on mute and I cannot... Answer This...
In Dash Receivers
car cassette radio: Clarion...
The front panel is removable.... Answer This...
In Dash Receivers
Pioneer car stereo...
need to know wich wire (color )... Answer This...
In Dash Receivers
wont stay powered on
i have a jvc kd-g340 car deck... Answer This...
jensen vm8012 lcd screen
I recently took a jensen vm8012... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
