Question about Refrigerators
Fluctuating temperature Danby DAR604w Intermittently the refrigerator that is set at 41 will suddenly go down to 32degrees. This is strictly a beverage refrigerator for us and as such can be quite a mess as bottles break. This has happened 3 times in the year since we purchased it. The first time we considered it a fluke, but it has happened 3 times without us touching a control panel. What is wrong with this?
I Have the exact same problem with my DAR604W. I supect the main board is not reading the thermostat. And that is a loigic issue. I hate my fridge because of it and will turn it into a boat anchor if I can find a solution on the web. Did you ever get it fixed?
Posted on Jan 08, 2010
    Novelist:
  • 87 Answers
If you have an internal fan motor circulating air around the inside of the cabinet, then I would suspect this as the first port of call for a problem (ie if the fan motor stops on either the door control or of its own accord and the thermostat is an air sensor then it will not be satisfied). If not then you probably have a faulty thermostat. Both of these options are pretty standard problems for a fridge guy so I would contact one to check the cabinet over. Hope this is of some help.
Posted on Mar 13, 2008
My magic chef mini fridge jumps from 55 to 49 degrees and it's set at 41. What can the problem be?
The first and simplest cause of unstable temperature readings occurs whenever people open the door, which almost immediately causes a change in your refrigerator/freezer's internal temperature. In this case, the temperature recorded by the electronic monitoring system is often comparable to a conventional thermometer located in the cabinet. What personnel often don't realize is that typical mercury thermometers have response times measured in minutes, meaning that it can take 5-10 minutes for the temperature shown on the thermometer to stabilize at the new value after a rapid temperature change.
A second source of temperature variation arises from the normal cycling of the compressor used to cool the refrigerator/freezer. Again, if the temperature displayed by your thermometer is being compared to the temperature reported by your electronic monitoring system, the response time of the thermometer may be masking the actual temperature fluctuations in the cabinet.
The final cause is due to electrical noise in the temperature monitoring system. This can often be identified from the temperature data in the form of random jumps in temperature from 0.5 to 5 degrees or more happening over a very short time period (such as seconds). The most common cause of electrical noise is the placement of wires from the sensor.
Sep 29, 2016 | Magic Chef Refrigerators
My frig motor runs more than it should
Each time the door is opened - temperature drops due to sensitivity of the sensor and the compressor switches on until temperature setting is achieved again. De-sensitise the sensor tip by attaching a square of Jelly from a dissolvable pack - it will stop the sudden temperature fluctuation triggering the compressor and save electricity also, but still allow the setting to remain unaltered, just not so reactive each time the door is opened for short duration access.
Jan 18, 2012 | Refrigerators
I came home from work and my alarm was on. The temperature on both the refrigerator side and freezer side was going up. The food in the freezer is thawing and the refrigerator is barely cool. I thought...
Let it unplug for an hour and set temp to your preferred setting and then plug in again. This will resume to normal operation.
Be sure that electricity in your home is not fluctuating or surging as it will cause false alarm or your fridge. It can intermittently operate your fridge.
Thanks for asking
Jun 24, 2011 | Kenmore 76582 / 76584 / 76589 Side by Side...
How to make the kegerator colder
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Feb 05, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Fluctuating engine temp a/c sends out cold air intermittently
Here's the thing. The ECU will shut down AC if the engine temperature is too hot. If the coolant temperature sensor is malfunctioning (lying to the ECU) telling it that the temperature is hotter than it actually is, the computer will turn the AC OFF.
Sep 11, 2009 | Hyundai Motor 2003 Elantra
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Room temperature has not changed since hooking up new portable a/c
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Jul 31, 2007 | Danby DWC513BLS Wine Cooler
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
