Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Dispenser Dispenses neither water nor ice; it does make ice, just won't dispense.
  • 87 Answers
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Posted on Mar 13, 2008
Water dispenser does not dispenses water
Could be calcium, clean it out
Jan 25, 2015 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Cold water dispenser on new whirlpool side by side dispenses lukewarm maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Water Dispenser
water fill valve or if equipted need to cnage water filter
May 06, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
No water. Ice dispenses okay.
bad water valve, frozen water line or a plugged filter
Sep 09, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
396 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
