Question about Canon imageRUNNER 5570 Copier
Setting the copier to Double Siding as Default
How would we set our copiers to automatically do double sided copies?
Thank you for your help.
  • 62 Answers
Select the Double-side function that you require as standard. Select COMMON SETTINGS, found in Additional Functions (X) button. Select the Store Common Functions setting and press OK. Think this is correct, let me know? In order to reverse setting, follow instructions to get to STORE selection but select INITIALIZE. Hope this helps.
Posted on Mar 16, 2008
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
My printer won't let me double side while printing. When I go into the options, it isn't possible to click on the double siding, it's greyed out.
Perhaps this article on How to Enable the Duplex Option in the Driver Settings (Software) might help. Just click on this link: http://bit.ly/9cTKs1. If you need further assistance, don't hesitate to contact Lexmark technical support. Thank you for choosing Lexmark.
Sep 09, 2010 | Lexmark E250dn Laser Printer
How can i copy automatically on both side(duplex)???
On the cotrol panel under the clear plastic cover you will find two sided options:
single sided to double sided
double sided to single sided
double sided to double sided
Aug 15, 2010 | Canon NP 6650II Copier
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
Steps to make an automatic double sided copy
Hello sir; That is depend on your machine have duplex unit or not if doesn't come with duplex unit you can not do it.
May 30, 2009 | Canon imageRUNNER 5570 Copier
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 5570 Copier Logo
226 people viewed this question
old marine
old marine
