My averatec 3200h stopped
My averatec 3200h stopped producing full color on the external monitor port
Is there and adjustment or control to restore this port to the original color condition?
    Problem Solver:
  • 17 Answers
Maybe your external monitor is faulty.
old monitors usually have color problem.
try with a good working monitor.
then you will know if it is the monitor or you external port problem.
good luck
Posted on Mar 14, 2008
SOURCE:
Vertical gray lines
If you can obtain a desktop monitor used for PCs, plug it into the side port on the laptop. Start up the system and see if it runs OK on the external monitor. If so, the problem is with the LCD display on the laptop.
Feb 27, 2014 | Acer Aspire Computers & Internet
Toshiba satellite C855D-S5105 HDMI
For the Toshiba Satellite C855D-S5105, HDMI is an option.
If present, believe it to be on the Left side, same as the VGA port.
[General example of VGA connector (Port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Note* Color is not always Blue. Scroll down a little for VGA Cable example ]
User Manual states plug external monitor device into laptop, then turn external monitor device on.
External monitor device should automatically be seen by laptop.
If not press, and hold down on the Fn key, and at the same time, tap on the F4 key until the display option you want is shown. Then press the Enter key.
Touchscreen?
That requires a knowledge of Windows 8, which I do not have a full understanding of yet. The User Interface of Windows 8.
It isn't stated by Toshiba, (At least that I could find), as to if the HDMI port; is just that. An HDMI port, or a Mini-Port HDMI port,
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
There are HDMI adapters, and HDMI cables; that adapt from regular HDMI to Mini-Port HDMI.
There are adapters that connect to a VGA port, and convert to an HDMI port.
Not the answers you are seeking? Please reply in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2013 | Toshiba Computers & Internet
I have an Averatec all in 1 D100 that the screen has lines all through it...I still get a picture but it has lines
Lines is a LCD cable or LCD problem, sometimes it can be video card. Try to check LCD cable soldering, check LCD cable, try to replace LCD, befor do it check your PC with other external monitor - if external monitor works fine then do it...
Nov 14, 2012 | Averatec D1002UHCE-1 All-In-One Intel...
Usb ports stop working
Try a system restore back dating before this became a problem, if this fails you can reverse the process.
Jul 06, 2012 | Averatec 3200 Notebook
Does the Averatec 3200 Notebook have an usb2 port?
Yes, it has 3 USB 2.0 ports
Click here for a full review and specifications,
http://forum.notebookreview.com/notebook-news-reviews/6860-averatec-3200-notebook-review-pics-specs.html
Hope this helps. Thanks for using FixYa.
Jul 13, 2011 | Averatec 3200 Notebook
When I use the external monitor S-video port on my Dell Inspiron 1721 running Windows 7 it only displays in black and white despite the internal monitor showing the screen in color.
Okay. For Windows Vista OS.
Go to Control Panel.
Under the Control Panel Home, select Additional Options at the bottom right of the list.
Click on Appearance and Personalization:
At the top right corner of the dialogue box, under Personalization, select "adjust screen resolution"
This will bring you to display settings:
Click the button that says "identify monitors" As each is displayed, it will present a number for which is the default or main monitor (1 or 2) 1 is the main monitor.
To change the external to the main or number one monitor: simply drag the #1 monitor to the left side (if not already there) If it is, you'll want to set the external as the default:
Do this:
While in Display settings, if the external is the #1 monitor, make sure to check the box for "extend the desktop to this monitor" and "this is my main monitor" for the external display. This should switch all settings to the external monitor.
Also, make sure the the resolution is correct for the size monitor you have. For a 20" (such as mine, external Dell monitor) the resolution is at the highest (1920 x 1080).
Also make sure it reads (to the right of that) "highest 32 bit). If this is not an options, make sure you're adjusting the external monitor and not the laptop screen. Otherwise you may need to upgrade your video card.
You should not need to do this though.
After you have set this, go to Advanced Settings and select Monitor. You will see at the top, a list of two monitors; your external with it's brand and name - and the laptop screen type and name. Select the external monitor name: Click on properties, drivers and Update Driver, then select to Automatically search online for driver.
Please let me know if you need further assitance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
When pluging in an exterior monitor, nothing apears on the exterior monitor?
Try power up the monitor first then the notebook.
This will automatically switch the video output to the external video port first. If this doesn't work then most likely there is a video card fault.
Dec 24, 2009 | Averatec 1000 Notebook
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
I have no color red on monitor.
Confirm the "no color red" by testing with another PC. If the same condition check if a color adjustment on the monitor is possible... like maybe a default setting. If the monitor still produces a bit of red it might be possible to edit the color adjustments using the advanced graphics adjustments; or a graphics program that your computers' manufacturer has available on your computer.
If nothing works the monitor may need repairs.
Jul 08, 2009 | Computers & Internet
My averatec 3700 laptop is not performing properly. When the computer is powered on, I hear the fans as usual; the "Averatec'' screen flashes for a couple of seconds; then the screen goes black. I can...
Does not sound good, the onboard video chip is more than likely fried. all you can do now is try plugging in a external monitor and see if that port still works. You may try replacing the LCD inverter board, but I don't think it will help.
Jul 07, 2009 | Computers & Internet
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
42 people viewed this question
Ekse
Alun Cox
