Resetting the Memory/Clearing the NVRAM clear all Faxes stored
CAUTION! Resetting the memory/clearing the NVRAM will erase any saved phone numbers and restore the printer settings to the factory defaults.
Step Action
1 Power off the All-In-One.
2 Press and hold the number 5 button and turn the All-In-One back on. Keep the 5 button held down until you see the standard Copy menu. This should take 8-10 seconds.
3 Press the menu button and use the down arrow button to find option 11. Manufacturing Menu. Press the check button.
4 Press down arrow button until you reach option 9. Clean NVRAM. Press the check button. The printer will display Clearing and then restart.
5 You will be prompted to go through setup again.
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
printer will not communicate with the computer
