Question about Wacom Cintiq 15X Graphic Tablet
USB Cable I have a Wacom Cintiq Intous moniter, purchased in 2002...........the usb cable does indeed plug into the underside of the Wacom Cintiq.........however, this same usb cable ENDS in an standard electrical plug in.....to an electrical socket........as does the power cable..........the tech people in Washington [cintiq guys] say that my USB HAS to be connected to my IMac..like the VGI cord.....and it never has........according to them, thats why it no longer interacts with the pen.....only the mouse.......can I get this repaired someolace, or am I gonna haveto buy a new one? Thanx kind sirs....... jimwiz@ameritech.net
SOURCE: wacom 12 wx cintiq
I had the same problem at first but managed to solve it. In my case I was setting up in tandem with another monitor and once I had correctly set the pixel dimensions of both monitors and set them to to 'mirror' mode it works pretty well. The only issue now seems to be a slowing of stroke speed ie the cursor lags behind my strokes. I have downloaded a new driver but not installed yet. Does anyone else have this problem?
Posted on Aug 31, 2008
well, sir try to reinstall your driver, restart your computer, and install it again.
Posted on Oct 08, 2008
SOURCE: Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Posted on Feb 18, 2009
SOURCE: Wacom Cintiq won't turn on
Hi Joni Lu: I had the exact same problem with my Cintiq 21 UX. Mine is similarly, about 5 years old. I called every where looking for an authorized or unauthorized repair shop... but to no avail. I finally called Wacom tech support and they told me the unit had to be shipped to Vancouver Washington to be repaired in a "clean" room because of dust. Knowing the expense that would incur (I'm in Toronto Canada), I deliberated for a few days before deciding to open it myself. The reasoning being I could see the back of the power button plate through the air vents in the back. I don't think the power button assembly was part of the sealed screen assembly. First I made sure it was unplugged. Then I lay it flat on it's front and took off all the screws. There's a copper foil that covers the back of the power button and screen controls assembly. After lifting it off I jiggled the wires, unplugged and plugged the wire connectors for the power button and the screen control sections and made sure all the screws were tightened. After replacing the back and plugging the power plug in, I tested the power button... and LO AND BEHOLD it worked perfectly!! Cross my fingers, it's been an hour now it's still working. I think I may have saved myself 3 grande by taking this initiative. Hopefully this helps Joni_Lu.
Posted on Jan 21, 2010
  • 3 Answers
On my imac screen under preferences/display-if I click mirror images it allows me to work on both surfaces but it then turns the color all whacked in my cintiq monitor and when I try to calibrate it -nothing happens.Any suggestions?
Posted on Feb 23, 2010
Connect 12wx via usb, no picture displays
see the link below.(in Japanese)
http://tennaru.blog97.fc2.com/blog-entry-160.html
DVI-USB converter(I-O data: USB-RGB/D2 ) seems to fit with Cintiq12wx.
Dec 19, 2010 | Wacom Cintiq 12WX Interactive Pen Display...
After repeated tablet cable connection checks and re-installing the Wacom tablet driver software, the tablet calibration window displays: "USB Tablet not found". Re-started my computer (Mac)...
The unit seldom has these kind of issues especially with mac computers. If it were windows then such would have been a normal phenomenom but with a mac then the issue is peculiar. First what you should do is try to trace all components of previous driver for the tablet on the PC and delete all components from the PC. Next get a new USB cable for connecting the tablet to the PC. This is usually done for trouble shooting purposes. after deleting all components restart the PC and then install fresh driver for the unit. Feed me back with the outcome of these activities.
Hope this solution has been helpful?
Dec 18, 2010 | Wacom Cintiq 12WX Interactive Pen Display...
I have a Sony vaio computer for my system I purchased the Cintiq 12W tablet. When installing these Items together I came acrose the problem of not having a vga dvi outlet so I was informed that I would...
use a dvi - hdmi convert cable and connect via the dvi-d cable on the cintiq instead of the analogue. should have been your first move as it is alot cheaper than an external vga card
May 15, 2010 | Wacom (PTZ930AC) Graphic Tablet
Wacom intuos3 led lights up for a second when plugged into any of my usb ports and then goes out. I've never had trouble with it before. I am using the usb ports on my Mac directly, no hub or keyboard...
try wiggling the cable at the tablet end.
I had the same problem, seems like the contacts from the cable to the tablet aren't that solid.
After a few wiggles I got contact again (pc made sound : a new usb device was detected), I just taped the cable so it wouldn't move again.
Oct 20, 2009 | Wacom Intuos3 6x11
May 16, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Problem with Cintiq 12wx
Hi...there Jenn!
Go to your toolbar bottom r/h side, look for VGA Display Icon. Open it and look for dual monitor setup. It's might be what you has been looking for... If not, read your cintiq user guide... Have a nice day!
Feb 03, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Wacom tablet won't read pen
Hello there. Sorry to tell you but no. the graphire and intous pens are 2 different animals. one has 512 levels of sensitivity and the other has 1024 among other things. you have to get a new pen.
Nov 20, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Wacom Cintiq 15X Graphic Tablet Logo
100 people viewed this question
Top Wacom Computers & Internet Experts
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Alun Cox
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
