Copiers
Problem for Copiers
Generic problem for all Copiers
Lines
By MelissaG on Mar 13, 2008
Copy has black line that runs down the middle?
Same Problem
Jun 07, 2008
-   My Canon 940 copier has a soft black 1/2 inch line running down each copied page. I pulled out the cartridge and opened up the long bar exposing a red roller bar which appears dirty and matches identical where the line is on my copies. How do I clean this roller bar? Thanks. -   Guest
Best Solution
posted on Mar 13, 2008
Helpful)
tryit
Rank: Guru
Rating: 89%, 1295 votes
I will give you all the reasons I can think of.
1, If the line is only there when running through a document feeder and not there off the glass. The small strip of glass directly under the document feeder is dirty.
2. The drum has a scratch on it, or the cleaning blade is not cleaning the drum properly. Would require that cartridge replacement.
3. The fuser roller may be work in the middle. You would notice some reprinting , or ghost copying if that were bad.
4. Less likely would be some piece of fuzz in the light path, or a small piece of paper or tape in the paper path smearing the ink across the page.
If your machine prints, see if the line is on a print, if its on a print and not on the copy then it is scanner related.
Comments:
Mar 14, 2008
- I cant believe i said that. My last line is 100 percnt backwards. SO sorry,
If it can produce a print, and the line is NOT on the print, but IS ON the copy it is scanner related.
And to think I don't drink or do drugs LOL.
So sorry.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
Hi, do you service Konica Minolta copiers models 7255,7145,or Bizhub C351.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
