Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Driver for KOGI Monitor.
Dear Fix Ya'!
We just purchased a new ACER M3100 Desktop computer and cannot get it to run, except for being in SAFE MODE, with my KOGI LCD Monitor Model # L7EH-TA. From other sources I understand I need a driver for the monitor but I cannot find one anywhere. I would really appreciate it if you could guide me, send me or point in the right direction to find one. The phone Tech @ Acer told me that since the monitor is appx. 5 years old that Window VISTA may not have a driver available. If you know of a driver please be as specific as possible as to where I go to download it.
Thank you for any help you can give me.
Sincerely, Jane Pinard
frogpole@comcast.net
  • 3 more comments
  • patty56 Apr 01, 2008
    when i plug in my kogi monitor,also 5 yrs old ,i get a command mode
  • tito2008 Apr 05, 2008
    I get an out of range on my kogi monitor where can I get drives?
  • Anonymous Apr 08, 2008
    I have the same Kogi monitor and am using XP. Is there a driver?
  • tswanson2 Dec 04, 2008
    Brand new Dell with XP. KOGi L7EH-TA worked fine on previous Dell, On the new unit the screensaver never activates. Poss driver issue. Where can I find the driver?
  • andergar Jan 04, 2009
    Love my KOGI monitor but when I bought a new HP Pavillion - there is not display on the screen. It's getting power as it flashes for a second but goes dark. Has anyone found new drivers that will work ?
  • 151 Answers
You can try it from driverguid.com or its regional site.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Mar 14, 2008
    Problem Solver:
  • 5 Answers
For Vista, try this:
In hardware manager, double-click on 'Monitors'.  Double-click on 'Generic Non-PNP Monitor'.  CLick on 'Driver' tab.  Click 'Update Driver'.  Then 'Browse...', then Let Me Pick...', then 'Generic PnP Monitor', then 'Next'.  Should be good to go.
Posted on Jan 29, 2009
    Problem Solver:
  • 10 Answers
Until you find a driver try this. Right click on a empty spot on your desktop and click on properties,
Click on the settings tab at the top and lower the screen resolution to 800 by 600 or 1024 by 768. click apply, exit and reboot. Vista is set by default to run high and the old monitors can't display it.
Posted on Mar 20, 2008
I have a Kogi l4ax monitor that I am trying to hook up to a Dell Dimension 7000. The monitor works on my dell dimension 4550. When I start the computer it shows the windos Xp screen for 2 seconds then...
Are you able to boot in SAFE MODE? since your monitor works on one PC, but not another, it could be your screen resolution settings in the OS on the 7000 - safe mode loads only basic windows components - and you should be able to get to the desktop and reset the resolution down to a size that suits the monitor you are using. Alternately, if you are not comfortable with uninstall tools or don't want to waste a day going into safe mode all day long to fix something which may not need attention, if you have access to a spare monitor you can try it on the 7000 and see if you get the same message at normal startup - if you don't - you can lower the resolution a tad once you get to the desktop, shut down as usual, hook the I4ax back up, reboot and see if it works. Either of these suggestions will only cost you a bit of your time - zero money and should have no negative impact on your OS or any associated hardware. This is a simple DIY deal and worth a try at least.
Dec 18, 2017 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Monitor is black
Try booting in safe mode per instructions here: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
You need to find out if the proper video card driver is installed when you use recovery disk. Compaq usually supply separate disk for the drivers.
Try using resolution of 1024x 768 @60 Hz first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 04, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My acer m3100 does not connectto my monitor
What it says on the monitor ? No signal ? If yes then:
1 - check the cable, eventually use another one and plug it in in the other video socket.
2 - check if the problem is a software one by trying to boot in Safe Mode - if you can then it's a software problem, uninstall your present video driver and reboot; then you will have to use an older version.
3 - if none of the above worked it's probably the video card - try to go in to the BIOS; if you can't then it's time for a new video card.
Nov 21, 2009 | Acer Aspire M3100 Refurbished Desktop PC -...
How can I download the info for my KOGI - L7CH - TA-AV53N-2000-KGX monitor. I did not receive a disk at purchase from Best Buy (they lose everything that is a display item!). I was able to use it...
Simply go on the Kogi website. be sure you know your purchase serial number and model numbers for prompt service.You should be able to access manuals and drivers ect....
Jan 27, 2009 | Kogi L7CH Monitor
Kogi monitor will not resolve screen
Startt the pc in SAFE MODE  and change thr resolution of the screen, the computer does not work on 1280 X1024, so AT THE BOOT TIME  PRES F8 chose save mode with windows, tan on the property of the display change the video resolution at 1280 X1024, and i think you don't have the video driver instaled not sure but u can chek that as well.chek run WINDOWS UPDATE if your diver is not in place. to chek driver take a look in computer management  DEVICE MANAGER.
Jan 20, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I ran a driver scan on my ACER Power2000 and the results said one of my drivers was out of date. (Unfortunately I didn't note which one it was, except that it was an Intel.) So I downloaded and installed...
Hey
Ok, the resolution the computer is using now is out of the range that is supported, try another monitor or try pressing F8 on the startup to get the advanced startup menu then select safe mode, in safe mode uninstall the driver you installed, this should return it to normal, then restart the computer and in normal mode you will need to install the old driver to get everything back to normal.
Dec 04, 2008 | AcerPower 2000-UD431C - Core 2 Duo E4300...
The color on my new Acer X193W monitor is that of Safe Mode,but the computer is not running in safe mode. I cant seem to change it to the normal colors.
What graphics driver is installed? If it is Microsoft driver you may need to install correct driver. Try Update from Device Manager - Hardware - Display adpater - update driver
Nov 14, 2008 | Acer Computers & Internet
Does not work with new desktop
All you have to do is change the monitor resolution to that mode. That's probably the maximum resolution you will get with that monitor, video card, and comptuer.
Aug 13, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
No Sound on my Acer Aspire M3100 PC
They have the new drivers on their website. Updating the drivers might fix your issues. Just type "acer aspire M3100+Drivers" into google and it should be your first option.
Jun 19, 2008 | Acer Aspire 3100-1405 Notebook
'Input Format Not Supported' (please help me!)
OK try booting up in "Safe Mode" Press F8 just after Turn on, when and if ya boot into safe mode then adjust your Video settings to say 1024x768x32bit and then reboot, if all good then when you are at the desktop, then adjust the settings to whatever you require... maybe 1280x1024x32bit.. Ya all good. If this doesn't work.. try the Monitor on another PC.. see if it works... if it does.. then maybe ya Video card is going/gone "Toes up" if not, then ya got a fault in your monitor, usually some sort of Power Supply problem or the like.
Jul 23, 2007 | Acer AL1916B 19" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
2,265 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
