Problems with Denon DVD Player
This DVD player plays a DVD disc for about 15 minutes only and then stops ... We are unable to watch the full length of any DVD ... Any ideas ?? What are your fees ?? Please advise ... Jim Turk
  • DiegoGlenn Mar 14, 2008
    Thanks VERY much for your diagnosis ... I would appreciate an additional response to my service query, just for comparision ... Another aspect of this problem: After the disc just shuts down, the red On/Off light blinks repeatedly and the OPEN button must be pushed many times before the disc drawer opens ?? Help !
  • 13,433 Answers
This is highly unlikely but still there is a chance that the mechanism operateing the reader lens is unable to move after a certainpoint inside the drive and therefore always stops the playback at 15minutes.
You could open the device clean the pickup, but dont touch the lens. you can try pushing the lens to both ends carefully or by spining the metal bar witch is connected to the lens motor. That would move the lens to both ends.
#WARNING#
I do not recommend that unless you are handy with electronics and you are prepaired to possibly avoid warranty. proceed at your own risk.
#WARNING#
And then Il quote the gury Ginko
"If it is under guarantee contact Denon for terms. If not bring it to a local service shop and have power unit tested."
Posted on Mar 14, 2008
  • 818 Answers
Some DVD players have an Auto Power Off feature. If this feature is activated, the RS-232C commands on some models will be ignored as the player is in an auto mode. To gain RS-232C command control, simply turn this function off.
  • 19,396 Answers
I will exclude dirty lens, because in this case it usually does not read the disk at all. If it turns itself off completely (shut down) always after 15 minutes then is most probably an overheating problem, usually it is the power adapter in need to be changed.
regards
Posted on Mar 13, 2008
  • 4,889 Answers
Maybe all you need is to dust off the DVD player's pickup. I have had this happen several times with several players. After dusting the pickup, those players are still in service.
If this doesn't work then what might be happening is a misread of the disk or a buffer error, these happen often, and can be fixed sometimes by cleaning the lens, cleaning and relubricating the guide rails and making sure the rubber bumper gromets are not worn down. Now these are all of the mechanical things you can do. The problem could also be a bad memory sector in the play back buffer, or a store and hold voltage could be off a bit (indication of a bad capacitor).
  • eagle338
    eagle338 Mar 14, 2008
    As i have indicated the tray mechanism is faulty i have just put it in techinical terms as to what could be the problem with it.. Go through my post once again and post back..
Progressive scan problem
You need to clean your laser lens my friend. If that does not help, I'm afraid then that your laser assembly is going bad and on its last leg. The first clue to this is that you stated that the Cd's work and the DVDs do not work properly. The laser, when it gets weak, starts to mess up on the Dvds first but the Cd's will soon follow. Good Luck
Sep 05, 2007 | Denon DVD-2910 DVD Player
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Mar 02, 2010 | Denon DVD-1740 DVD Player
Can't format disc
I guess the DVD player that you are using is incompatible of playing DVD -R
Please check if it can.
Nov 16, 2008 | Samsung SCDC163 Camcorder
Screen just flickers when I put a disc in the player.
My dvd player will show the movie for awhile the it would stop turning and go any further. I would say it plays for 15 minutes any suggestions
Jul 21, 2008 | Dynex DX-PDVD7 Portable DVD Player
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Mar 08, 2008 | Televison & Video
DVD player
Clean the pickup using a commercial cleaner disc.That's the only quick,cheap fix.
Dec 12, 2007 | Toshiba MW20FM1 20 in. Combo
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
