Question about Microsoft MN-700 Wireless Router (p5308j)
Getting dropped by the MN-700
When using MN-700 and try to encrypt at 256, can only get limited or no connectivity. No problem without any encryption in b or g. Any suggestions?
  • 73 Answers
Try latest firmware update ok see if that fixes the issue microsoft.com site or custum windows update then re do settings u dont relly need 256 bit man ok 1268 fine with reg password
Posted on Mar 13, 2008
Need password to add a new laptop
on first laptop go to network and sharing in control panel and then change adapter settings choose your connection and right click and choose status then (if using wireless) go to wireless properties and security tab it will have your password, just check the box show characters.
Dec 28, 2012 | Microsoft MN-700 Wireless Router
How can i change set up from TKIP to AES
This model does not appear to support AES, so you won't be able to change it.
Feb 28, 2011 | Microsoft Broadband Networking MN-700...
I need the code to connect my laptop to my wireless router to use the internet
You need to configure the "wireless" settings within the router:
* set an SSID
* set an encryption-level --- use 'WAP'
* set a password.
Then, use those settings on the wireless-adapter on your laptop, to connect to the router.
Nov 26, 2010 | Microsoft Broadband Networking MN-700...
How do I install my WEP number
go to 192.168.1.1 If you have already configured the router for internet access, then just click on "configuration" otherwise, go through the steps to configure it according to your ISP's instructions, then click on configuration. then wireless. Then go down to privacy settings.
Pick which authentication type to use ( I recomened open)
Then pick the highest encyption meathod that all of your wireless devices are capable of. 64-bit, 128-bit or 256-bit.
Most devices use 64 and 128 bit, but if all of your devices use 256, then use it. Then create a wireless key to use.
If key select is selected, the WEP Key is treated as a string of text characters, and the number of characters must be either 5 (for 64-bit encryption) or 13 (for 128-bit encryption) or 29 (for 256-bit encryption).
If not selected, the WEP key is treated as a string of hexadecimal characters, and the number of characters must be either 10 (for 64-bit encryption), 26 (for 128-bit encryption), or 58 (for 256-bit encryption). The only allowable hexadecimal characters are 0-9 and A-F. (My hint is to use hexadecimal, it is eaiser)
If you would like to create a new WEP key go to this site (http://www.powerdog.com/wepkey.cgi) and type in a passphrase and click generate. it will generate 4 64-bit keys and 1 128-bit key.
choose the best bit 64 or 128 bit, then copy and paste it into the correct key box(es)
Oct 12, 2010 | Westell Wirespeed VersaLink...
Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
    The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Broadband wireless adapter limited connectivity issues
    If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
    To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
    1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
    2 On the Home Network menu, click Wireless.
    3 In the upper-right corner, click Details.
    4 The wireless Access Point page appears. Under:
    - Configuration, you can find the network name (SSID).
    - Security, you can find the encryption.
    On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
    Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
    Nov 27, 2009 | Computers & Internet
    LG KC910 connecting wifi to my home internet
    I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
    Feb 02, 2009 | LG KC910 Renoir Cell Phone
    WEP Encryption
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
    WEP Encryption
    Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
    Microsoft MN-700 Wireless Router (p5308j) Logo
    163 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
