Question about Casio EXILIM Card EX-S770 Digital Camera
Will not come on
Dear Friend,
When I press the button to turn on the camera, normally
the lens cover opens and the lens zooms out. All of a sudden when I press the button to turn on it will not do anything.
When I press "on", I get no response. Also, when I charge, I get a blinking red light instead of a constant one. Taking battery / memory card out and putting it back in doesn't seem to help. Any other advice?
I have the same problem. My camera will not turn on. I also have the ex-s770. I sent it in to Casio because when I called them about the problem they said it was not the battery. They sent me a letter with an estimated bill for a flat fee charge of 126.95 and they said it may cost more, because they will not checked it out until I pay. Another option was to sent them a check to have them return it back to me and another option was for them to keep it. Or I could also buy a refurbished one that would have a 90 day warranty. I had it sent back. I paid too much to just give up on it, but I want it fixed. PLEASE HELP!
  • kathy77 Mar 17, 2008
    This request is not totally mine. The first part is someone elses. Mine starts off with that I have the same problem. Mine will not go on either, but I do not have the problem with my red light flashing on the cradle. My situation is that it will not hold a charge for very long. After I charge it I can use it for a little while. Then if I go to use it later and not put it back on the charger it will die. I bought a new battery, but the problem is still the same.
  • 4,889 Answers
Remove the battery then press and hold on the power button for at least 10 seconds. Then replace the battery and turn on. This is a hardware reset that can be done on most electronics. My advice for you: NEVER buy Kodak and Casio Junkyard products. I have seen lots of unhappy customers..
Posted on Mar 13, 2008
  • eagle338
    eagle338 Mar 13, 2008
    Repeat the process for 10 to 15 times. I have solved this problem for many frustrated customers
  • eagle338
    eagle338 Mar 18, 2008
    This might be a firmware problem... it may be sending falls battery low error messages.. try updating the firmware.. i am positive that it will resolve this issue
    Sergeant:
  • 201 Answers
Hey there Kathy77, the blinking red light you see indicates a defective battery. I would suggest you take it out and clean all the terminal connections with an eraser. If this step does not help, replace battery with a new one. Also please ensure your battery is seated correctly. Good Luck!
  • Casio Master
  • 19,396 Answers
Well there are two different case in your post. If you are in case A (dear friend post) , then I can try to find a fix, the problem may be shutter locked, sensor, electronics etc.
If you are in case B (fee 126.95 from Casio) then there is nothing to do, probably board inside must be replaced and it will cost nearly the price of a new camera.
A way out of this may be buying a faulty camera of same kind (maybe on ebay) and getting the board replaced by yourself or a local repair shop, I am sure it will be cheaper than what Casio estimated.
regards
  • Ginko
    Ginko Mar 13, 2008
    If you are in case A instead remove and place back the battery couple of times. try to start camera. then move the mode switch and try back to start camera.
    Check if the shutter in front of the camera try to open when you press on.
    Additionally , if camera had recently been exposed to humidity in a wet place , or had been in contact with water, leave it in a dry and worm (not hot) place with battery out and battery door open.
    If all this does not work bring it to a local repair shop before sending it back to Casio.
    If the camera is under guarantee instead, contact Casio as soon as possible and eventually send it to them.
  • Ginko
    Ginko Mar 13, 2008
    Well kodak and casio are two exceptional brands. The first keep building and inventing most important innovation in the sector (Kodak). The second one built the strongest lcd watchs in the world. In any case this is my personal opinion. Both brands build and distribute high quality devices at an affordable price, then someone may be disappointed sometimes.
    regards
My camera stopped working suddenly. When I turn
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jun 01, 2010 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
Hi my camera is telling me to...
Is the camera turned on? Removed the Cap on the Zoom lens? Try turning it off and on, while the cap cover on the lens is removed, then press the heart button and take some photos. What specifically is the warning?
May 07, 2009 | Panasonic Lumix DMC-FZ4 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Will not come on
I have the same problem. It looks like a defective battery as I tried a friends battery and the camera worked.
Mine is less than a year old so not happy.
Feb 12, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Will not come on
try taking the memory card out and then powering the camera on and off
Nov 18, 2007 | Casio Exilim EX-Z57 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Kodak EasyShare CX7530 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
