Question about Sony Playstation 3 (PS3) Console
No video - blue screen...
Bought PS3 used - I have unit hooked up properly, this I am certain...no video cable w/ unit, so I purch. component AV cable for PS3 and PS2; results of 5 sec. reset is nothing - same blue screen.... can anyone help?? thx
  • madmax777 Mar 14, 2008
    thanks for the two responses... last night after waiting (2) - 15 min intervals, I spoke to PS3 rep and they tried to get me to xchange and PAY $150 to swap out, so I declined said unit was from trusted source and only used twice... so he had me hold start button until 2nd beep and THEN I saw the black screen w/ all the options -next, I erased his memory data and set unit to 1080i per diagram, turned off and switched cables from 480 cables to AV cables, turned back on and game loads w/ sound! hope this helps someone else....
Since you bought this console used, it maybe set to HDMI 1080p/ 1080i/720p output(by the original owner) and if your TV does not support this there will be no picture, the only way to lower the output resoloution is to get into the options menu but to do that you will need a freind with a tv that supports whatever resoloution its been set too.
Posted on Mar 14, 2008
    Problem Solver:
  • 22 Answers
PS3 is The amazing device by sony but it has some common problems like sound , video/picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 14, 2009
  • 33 Answers
Your 3rd party component cables may be the problem as the conections for the ps2 and ps3 are way different if you look at the pins on the male end.You should at least hear audio if it is compatible and you hooked it up correctly. If no audio then your cables are hooked up incorrectly or faulty. Go on ebay and look for the actual av cables for the ps3. If your TV has HDMI slots hook it up that way.
Good Luck
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
Just bought a used ps3 and when I hooked it up to my sd tv via av it worked fine, but then when I went to hook up t up to my hdtv via av also it will not display any video or audio.
Make sure you are on the correct input, try purchasing component cables and using them(Has a red green and blue plug for video and red white plug for audio) make sure the AV on the TV works try plugging something else into it like a DVD Player make sure you switch your video setting to the correct format.
Jul 02, 2013 | Video Game Consoles & Games
Trying to hook up av combo cable to an emerson tv for a ps3 and xbox using components not hdmi red white yellow blue green red
What do you need? what they are? Yellow is video, red is right audio, white is left side audio. the others are for HD. Good luck. ^^
Mar 29, 2013 | Video Game Consoles & Games
Bought a used gamecube....hooked it up properly, we think, but have audio only ...no video....suggestions
I suggest trying to use a different av cable from the gamecube to the tv, also try using the av cable you have on another unit, the cables are also exchangeable with the nintendo 64 av cable, so if you have a N64 laying around you can test with that cable. Good luck.
Apr 20, 2010 | Nintendo GameCube Console
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Sound but no picture
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Play station 3 and tv
The ilo dtv 2784 can be hooked up to the PS3 a few different ways actually!
1st - It can be hooked up through "component" cables. This is the red, green and blue connectors (video) with a red and white connector (audio). You would need to buy the component cable specifically for the PS3. This would be the "best" quality, and this link is just to show you what it looks like (they can be purchased at almost any store that carries electronics.
http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1238741997&sr=8-1
2nd, you could hook it up with "composite" cables, which are the standard cables that most of us have used at one point or another. It is the "yellow" connector (video) with the red and white connectors which are (audio). This cable will not give you as good as quality, but it is cheaper if money is an issue.
http://www.amazon.com/AV-Composite-Cable-Sony-PS3/dp/B000SEU92W/ref=sr_1_1?ie=UTF8&s=electronics&qid=1238742142&sr=1-1
Please don't forget to rate my answer "FixYa" if this answers your question. Bye pannbjoosten!
Apr 03, 2009 | Video Game Consoles & Games
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
754 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
