Question about Sony KV-32S66 32" TV
No Power I have a little Sony KV-8AD12. It started buzzing near where the power cord plugs in. Suddenly I have no power to the set, although I still hear the buzzing. Does that sound like a power supply or something else? Thanks.
  • werz Mar 17, 2008
    eagle2:
    The power cord was not the problem. I have an uneducated guess that it is the power supply.
    Thanks for your suggestion.
  • 44 Answers
Hi: That could be the power cord itself shorting out right near where it plugs into the set.
DO NOT hesitate removing the plug from the AC wall plug, since fires have started this way!!
If its the cord you can replace it or if its inside the set it will need repair.
Posted on Mar 13, 2008
  • Albert Nika Mar 18, 2008
    Hi: Ok best to be safe than sorry. The power supply then has shorted out. You still should keep the set unplugged, since the the remote circuits keep it energized.
Sony KV-27S65 27" Television suddenly has very low volume
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Jun 03, 2010 | Sony KV-27S65 27" TV
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-32fs10 won't turn on...stand by light blinks continuously
No,ur power ic board converter is dead.
U need a new one.U know some Electronics repairs,open it take off the board where near the A/C cord plug in is use the parts numbers buy it from the Web.replace it that might work, if only the power prob.nothing else.
Aug 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-32S45 32" TV no power
If the power plug is fused (like in UK) check the fuse inside the plug.
Test a different power socket.
If there is no power at all, and the power cord is good, then it is a faulty power suupply board. Probably a capacitor on power board had blown.
The board must be tested and repaired by a technician.
Jan 06, 2009 | Sony KV-32S45 32" TV
FUSE SPEC FOR SONY KV-36FV16
The rear panel nameplate will state the unit power requirements. Look for number of amps draw. Let's say you read "2 A". Now, depending on where in the circuit this fuse is, your fuse size will be no more than two amperes (sometimes slightly greater if slow-blow fuse spec'ed). So, if your fuse is located immediately near the line-cord entrance to circuit board, start with a 1.0A fuse. If that immediately blows, then increase to a 1.5A fuse. Repeat until 2 A fuse is reached. If still blowing, then there is a problem with the set, either power supply or tube.
Jul 17, 2007 | Sony KV-36FV16 36" TV
Sony KV-20FS120
It's normal for new sets, especially Sonys to do that due to some sort of gas build-up in the new tube. My set still gets a high-pitched buzz after power on and lasts for a minute or two before silencing. If the hissing continues when the TV is turned off return it to the shop ASAP. It could be a problem with the power supply, something getting ready to blow up. Good luck
May 30, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-32S66 32" TV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
