Maytag neptune washer belt
The new belt specified for the MAH3000AWA neptune seems WAY too short- did they change the drum pulley?? Thank you,
Gordon
    President:
  • Washing Mach... Master
  • 2,651 Answers
No not too short place it over the motor pulley adn slowly wid it ove r the tub pulley( like you used to chane the bicycle tires as a kid. Its real tight but it'll go!
Posted on Mar 14, 2008
Neptune washer will not extrACT water
Not belt or pulley!
Pump located below drum blocked or filter blocked
May 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does the lr code mean
The code means locked rotor. Disconnect power to the washer and remove the rear access panel. Remove the rear access panel securing screws and pull the panel off the cabinet.
Turn the drum pulley by hand to determine if there's a restriction that caused the locked rotor error. If there's a restriction, remove the drive belt. Pull the belt from one side of the drum pulley then turn the pulley in such a way that the belt unwraps from it.
Turn the drum pulley and the motor pulley to determine whether the drum or the rotor is being restricted.
The outer tub bearing is damaged if there's restriction in the drum pulley. Specify the model of your washer for the specific replacement part/s and installation guide.
Try to free the rotor if it is stuck by forcibly turning it back and forth. Replace the drive motor if the rotor cannot be unstuck. Specify the model of your washer for the specific replacement part and installation guide.
Mar 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Drive belt on Maytag Neptune washer not centering on large pulley on rear of drum. The belt rubs against the veins of the drum ever so slightly and is rubbing a small grove in the rear of the drum. The...
Do you know the story of Kakima and Lil J? Many years ago, a great battle occurred. Kakima struketh with great force and angst, but i passed him, and prevailed. With the greatest achievement on the website, i ran. but kakima chased me, and called the admins! How dare he? What has he doneth to the lil J? He got me banned, and i retrieved balance. I never came back until today. Im finally back to the city of england.
Jun 28, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
The belt keeps coming off my maytag washer mo. mah55flbww. tub bearing seem good motor seems ok
That is a tough one, especially since you indicate that the bearings are okay. The belt not wanting to stay on a Maytag Neptune washer usually does not bode well. It is usually an indication that the drum bearings are shot. Look for brown splatter on the back of the drum and the inside bottom of the washer. The presence of any brown discoloration is a pretty good indicator that the bearings are going. Anyway, hope this helped, sorry for your problem, and best wishes.
Jul 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Belt keeps coming off the pulley
I suggest you check your drum bearings, belt will only come off if misaligned.
Mar 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
