No output to monitor,graphics cards work,new psu, new ram, all lights come on and fans turn. the mobo is a winfast nf4sk8aa graphics - nvidia 6600gt x2 cpu - amd 4000+ ram - corsair 1gb 3200 value select hdd - maxtor 200gb
  • vimes Mar 14, 2008
    already checked graphics cards, seated properly and they work on my other machine, but thanks anyway.
Unplug power
re-seat video card
plug power - turn on all
windows comes up - else try another video card.
control panel under video uninstall then reinstall video driver
repair video programs or install video program
Posted on Mar 13, 2008
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Hi when I try to install vtx radeon hd 5450 graphics card no display is shown on monitor and all fans run fast computer appears to be booting but can't tell. compaq sr1519uk with MSI MS-7184 mbo,...
Hi Dave,
1. Have you ever tried testing your VTX HD5450 GPU to another system or try bringing it to the store where you purchased it.
2. After removing the VTX HD5450 GPU, did your Nvidia 8400GS worked? - If it works there might be a compatibility issue between your MOBO and HD5450 GPU if the card is good.
3. I think there is nothing to configure on your bios regarding Graphics setting because your Nvidia 8400GS worked without any problems.
4. Did you check the VGA/ DVI cable and power cable if it is plugged to the proper ports. There are times that even tough we are that good we miss something.
Hopefully this information helps.
Thank you for using FixYa.
Aug 20, 2011 | Computers & Internet
Asus M4A88TD-V EVO/USB3 BIOS: 1702 AMD Phenom II X4 955 PSU Ultra 500watt ATX RAM Patriot DDR3 1600Mhz 2x4Gb Mobo will not POST, no beeps, fans turn for one second and stop. Mobo replaced with same,...
So you changed everything except 1 thing, power supply. Try another power supply or power suply cord.
If it doesn't work, try another graphic card, maybe there is some shor circuit.
May 07, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
Power button does not light, fans run but computer does not send signal to monitor. Replaced power supply, no change. Put in new graphics card, still does not generate video that would allow me to change...
no HP PC stated just a MOBO. must we guess?
no the power button is just 2 wires, a digital line and ground
it must be plugged in to the correct MOBO jack.
in fact i can turn it on with a simple jumper wire, there.
i guess you found the board, in garage sale, just tossed in a box?
if the local vga jack and added in VGA card both fail then its a mobo issue.
im googling for you.
lets see what POPS
Compaq Brio ATX PGA370 New D7580-60003 *
This motherboard is only compatible with Celeron 400 CPUs
With integrated SiS Super AGP graphics controller?
takes 1 good RAM stick.
if the fan fails to stay on, that means the PSU sees errors.
mostly sees shorts on MOBO(remove things to find it)
that one old mobo is rare, now.
is the coin cell at 3vdc, or below 2.9v, if yes, needs new one.
HP has zero data (information) on this old mobo or the COMPAQ BRIO anything.
https://www.youtube.com/watch?v=3at_Ev2kOoI
Aug 13, 2017 | HP (D7580-60003) Motherboard
Foxconn NF4SK8AA-8EKRS will not post
I believe that there is no on-board graphics for that motherboard so I guess that you are using a graphics card?
  1. Try another monitor
  2. Try another cable
  3. Replace the graphics card
Sep 15, 2009 | Computers & Internet
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Dec 23, 2008 | ASUS A8N-SLI Motherboard
Trying to load call of duty 5 world at war . with g force 8800
It will say on the box it was packaged in what the minimum requirements are for the game....
Here is from a site i found....
Processor: AMD 64 3200+/Intel Pentium 4 3.0GHz or better
Memory: 8 GB free hard-drive space, 512MB RAM (XP)/1GB RAM (Vista)
Graphics: Shader 3.0 or better, 256MB Nvidia GeForce 6600GT/ATI Radeon 1600XT or better
http://www.nvidia.com/page/geforce_8800.html
link for your line of graphics cards.
You have not given the entire model # so it is unclear if your card is sufficient, however it does say GeForce 6600GT or better - which yours is
Dec 22, 2008 | Nvidia GeForce 8800 GT 512MB Graphic Card
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
AGP texture acceleration not avalable :(
Hi all, I am running Gigabyte M59SLI-S5 mobo, 6000x2 CPU, 4gigs 1066ram, 2 dvd-burners, a 6600GT vid card, and an X-fi sound card, all powered by a 650watt BFG PSU, in Vista Home Premium. Ever since I installed the new ram my pc is running very unstable, It isn't the ram as I've run various mem testers and what not. Every time I tell my PC to shut down it doesn't, not all the way. My monitor turns black, vid card and HDD turn off, but the RAM is still running (can tell because of the LED's on it), and so is the PSU (lights are on). What could cause this? I also don't have any viruses. I had problems with my old ram in this same mobo as well.
Also another problem is that sometimes when I boot my pc it has mobo Bios F4, and sometimes it shows an F8H. So it doesn't always boot under the same revision of the BIOS. I've tried flashing the BIOS and reupdating, but each time I do that it stays at the f8h version a few days then sporadically reboots in F4 or F8 revision.
What do I need to do? Get a new mobo? And is it unsafe for parts of my pc to turn off but the psu and ram not to? I wanted to wait until March or so to get a new mobo, but if this will damage other components should I get a new one now? I appreciate all answers, as I am completely bewildered by this, and no one I know has ever heard of this.
And a side note, I have checked my running temps and my CPU is about 40C under load and whole system case is about 27C under load.
Dec 06, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Computers & Internet Logo
114 people viewed this question
Alun Cox
David Payne
David Payne
