Question about RCA OPAL M4001 MP3 Player
No device recognized when connected to computer
My device is not recognized whenever I connect its USB cable to my computer. I tried unplugging and replugging and also re-installing the program. Nethier worked. Please help me!
Dont recognize my device when I plug it in the usb port!!!!!!!
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 25, 2008
Epson printer not conecting with computer
there might be a connection issue here. if it is connected using a usb cable, check if your printer is talking to the computer, that means you will check if the computer can recognize the printer when connected using a cable,
i hope you state the os of your computer, anyways,
if XP click start--control panel--classic view--system--hardware--device manager--universal serial bus controller--look for usb printing support
(if you found it, connection is good)
if it is not there, unplug and replug the usb and try again, try another port on the computer, if still not, try another usb cable, if both usb are not recognized, it might be the port of the printer or computer, ti=o isolate that, try another computer if thats possible.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 18, 2010 | Epson Stylus Photo 2100 InkJet Printer
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Why is my xp not communicating w/my epson stylus cx9400 fax series. The software is already install but the computer says that there is an undentify device connected to the computer to unplug the device...
try to connect the usb cable into another port on your computer, if still doesnt recognize, you should try it to another computer. if it works, then theres a problem with your computer, if not, you should try to use another usb cable or use another connector like a printer cable
Aug 16, 2009 | Epson Stylus CX9400 Photo Printer
SwiMP3 was not safely removed and now it is not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 12, 2009 | Finis Swi MP3 Player
Computer not recognizing usb connected nav device
Jun 05, 2009 | Magellan Maestro 3200 GPS
Computer does not recognize the usb device
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Computer does not recognize the printer
Mar 12, 2009 | Brother MFC 3220C All-In-One InkJet...
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
USB port does not recognize 1Mb flash drive
try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
May 17, 2008 | ASUS P5P800-VM Motherboard
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
good luck
please mark the post with a fixya
Feb 18, 2008 | Creative Labs ZEN V Plus MP3 Player
RCA OPAL M4001 MP3 Player Logo
113 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
